Question about Golds Gym Trainer 410 Treadmill
Motor works for less than a second - Golds Gym Trainer 410 Treadmill
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Pe error on whirlpool washing machine
Check the motor brush they surely are dirt you can also clean the collector where the brushes lays on
Jan 28, 2014 | Smeg WDI12 Front Load Washer / Dryer
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Intermittent start
Not a thermo fuse sound like motor is struggling.
May just need taken apart and cleaned
Ronco pasta maker stops on the mix mode
Your motor most likely has a short which is making it go to a sort of pause. The machine motor (the whole machine part not the insides) can easily be replaced on eBay or I just bought a new motor at Goodwill for $6.99.
Dec 26, 2012 | Ronco Automatic Popeil Pasta Maker
Kenmore gas dryer will not stay on, most the time i can get it to start, but it will not stay on.
the motor is cutting out on thermal overload. You can try removing the panel from the dryer and cleaning out any lint that may be piled on top of the motor causing it to overheat but more than likely you are going to need a new motor because once the motor starts going out on thermal overload it more than likely needs to be replaced.
Nov 14, 2012 | Dryers
Xbox disc tray wont open
Press the eject button wait one second and FIRMLY
smack the top of the console just above the drive and it
will open.
The cause is either a weak eject motor or to much grime
and build up in the Gears preventing the motor from breaking
the magnetic seal between the hub and spindle.
I normally just gap the hold down magnet in the drive
so the motor can break the mag seal with less force
and that seems to work well.
Rob
Oct 24, 2010 | Microsoft Xbox 360 Console
Turn key on,electrics good.start motor less than 30 seconds fuse blows.thanks
your starter motor is going to earth and therefore completing a circuit and blowing the fuse.
have the starter motor overhauled
Sep 20, 2010 | 1971 Yamaha XS1B
I have a riptide st 80 24 volt bow mount co-pilot. Still under warranty but has worked well for 9 months. When I start unit, it works well for 15 seconds (more/less) and then shuts off with the green on...
Start to look for the charge state of your battery.
Measure the voltage on the battery connectors when the motor falls out. If lower than 11v your battery is too weak.
Also check all the cables between battery and motor. Check foor loose connection or oxidation.
Aug 19, 2017 | Minn Kota Riptide St Saltwater 80 Bow...
Whiny motor, less suction
Its not unheard of that the lifetime filtration filter may need replacing and dust can work itself into the main motor chamber even though Dyson claim their models have sealed motors. Whiny motors however can happen for a number of reasons such as:
  • Over-use
  • Motor bearings
  • Strain on the motor from another source i.e. the drive belt may need replacing or the caps on the brush roller at each end need to be checked.
Have a look at the drive belt / sole plate to see if there is any dirt clogging the system. Also check the inspection pipes on the Dyson and check that nothing is obstructing the air waves. Sometimes even a new filter (bottom of the bin) cures the problem and this can easily be checked by taking out the filter for a couple of seconds and using the Dyson to check if suction is indeed stronger.
Jul 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Golds Gym Trainer 410 Treadmill Logo
29 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Steven's...
Steven's...
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
