Question about Maytag CentennialR EcoConserve Top Load Washer with Low Water Wash in White
Sensor light stays on while water loading, goes through cucle, but will not spin
Washer will go through cycle but will not spin
SOURCE: can't get washer to finish spin cycle
I have the same problem they can not fix it so dont waste your money on a repair guy they just run it through a dianostic test and tell you that you are no using the machine properly
Posted on Mar 14, 2007
huuum
  • 750 Answers
SOURCE: Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Posted on Oct 04, 2008
  • 79 Answers
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Posted on Feb 08, 2009
wpcustomer
  • 346 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    richroth
    • 9472 Answers
    SOURCE: Washer immediately goes into wash cycle when
    The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
    Posted on Jan 26, 2011
    Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
    Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
    Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
    Kenmore washer model #21302 lock on light is flashing, will not start
    Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
    May 21, 2012 | Kenmore Washing Machines
    Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Apr 21, 2011 | GE Washing Machines
    GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
    Are you sure you don't have a second rinse button that is selected.
    Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
    GE wpse4200aoww washer won't stay in spin mode
    Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
    Aug 23, 2008 | GE WHRE5260E Top Load Washer
    Kenmore 417.29042992 front loader washer
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
    Rate me pl.....if helped.
    Jan 23, 2008 | Kenmore 44102 Front Load Washer
    Washer problems
    Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excess water in the washer. Re-select the cycle and press HOLD TO START. If the problem persists, call a service tech.
    Oct 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore 2 Way Tumble Action Front Load Washer
    no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
    Jul 09, 2007 | Kenmore 44102 Front Load Washer
    Maytag CentennialR EcoConserve Top Load Washer with Low Water Wash in White Logo
    11 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
