Question about Saws
Kobalt 7 1/4 sliding compound saw, unlock the cutting head
Can't get the pin to move, ready to break it. Don't know if it goes left, right up or down. No diagrams, no arrows, no video...
  • 5 Answers
SOURCE: 10in sliding compound mitre saw
turn the bevel lock to counter clockwise
Posted on May 29, 2008
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
SOURCE: ryobi compound mitre saw sliding 10
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
Posted on May 08, 2009
  • 4088 Answers
SOURCE: I need a left-hand metric thread bolt that holds
Go to: searspartsdirect.com and enter the full model number minus the decimal point. Full drawings of all replaceable parts will be displayed as well as parts lists and prices. Hope this helps!
Posted on Mar 30, 2010
SOURCE: I need manual for kobalt
Call-18883Kobalt and they should be able to help you. Listen for the prompts to make sure you get the right service agency for miter.
Posted on Sep 17, 2010
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
How do I replace the linear ball bearing on a c8fb2 Hitachi miter saw
Its not too difficult:
1) There are 2 retainer pins located on the rear slide support (#4 on breakdown) - carefully drive these out with a punch - be careful to support the bracket so you don't break it.
2) remove the rear support and slide the saw head and arms out of the bearing.
3) Remove the 2 covers (front and rear) over the bearing
4) loosen the allen head set screw on the housing that holds the bearing in place
5) using a large socket and a plastic hammer - gently tap out the old bearing.
Reverse process to replace.
Do not use grease or oil on the bearing or slides - use a pure, clear silicone spray that dries completely - grease & oil attract & hold dirt and debris and will cause bearing failure.
Hitachi C8FB2 8 1 2 Twin Rail Sliding Compound Miter Saw Parts
Feb 14, 2015 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
How do u life up the saw sleeve (the thing u move to cut the wood) on my Kobalt 10-in 15-Amp Sliding Compound Laser Miter Saw
If your saw is completely intact, meaning no missing or damaged parts, the blade guard should rotate out of the way of cutting as the saw head is lowered to make a cut. You didn't give your model number but there should be a push rod or link plate from the pivot point on the base to the blade cover that pushes the guard out of the way as the head is pivotted downward. If you have the cutting head locked down to make sliding cuts the guard should be up and out of the way. If this isn't happening you may have broken or missing parts of the guard system.
Feb 17, 2013 | Saws
User manual for 251946 kobalt sliding compound miter saw
Try to find it on amazon, Amazon com kobalt saw manual, they have great amount of books, so, maybe you are lucky. I hope this helped. Cheers
Dec 02, 2012 | Bosch 12" Compound Miter Saw 3912
Edge of the saw blade moving left and right
check its mounting point(is it bent) is it mounted properly?
Dec 02, 2012 | Bosch 4410 10Inch DualBevel Sliding...
I need manual for kobalt sliding miter saw sm2505lw
Sep 15, 2010 | Bosch 12" Compound Miter Saw 3912
Ryobi compound mitre saw sliding 10" laser line is 1.5 mm out to the cut is there any way to adjust it
Apr 17, 2009 | Ryobi Circular Saw W/Dual Laser
Can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
Feb 20, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Locking mechanism on miter saw.
Push down on the handle . Facing the saw there is a spring loaded pin on the left rear side , right at the pivot point , pull out on it and raise the handle to the up position.
Jan 03, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Saws Logo
53 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
