Question about Miele 24 in. G665 Built-in Dishwasher
Spray arms not rotating.
None of the 3 spray arms are rotating although there does appear to be some water coming out of them and just dropping straight down to the bottom.
2 Suggested Answers
  • 297 Answers
SOURCE: How do I re-secure the bottom spray arm on my
you can't it is factory pressed.you need to replace the dishwasher.
Posted on Jul 15, 2009
Top blades Will Not Spin
Hi - I will suggest verifying that there is enough water pressure coming into the unit. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Oct 07, 2012 | Frigidaire GLD2445RF Built-in Dishwasher
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Why is the top sprayer is not rotating?
This dishwasher uses a pulsating mechanism to push water to each of the spary arms forcing water alternatingly in each arm. This ensures a strong spray is maintained for cleaning.
The pulsating action is obtained through a ball (see item 58 in this diagram). It is possilble that this ball is either stuck or is damaged and needs to be replaced.
Sep 21, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishes on the lower rack are not getting clean. The unit is about 3 years old and was working fine until a week or two ago. When I open during the cycle, it doesn't appear that the lower sprayer has...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 07, 2011 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
Suspect arms not rotating
there is insuffient water in appliance it needs 32 litres to wash properly and have enough pressure for wash pump to drive spray arms round this is quite easy to fix but messy, remove base panel plastic and metal one behind this exposing a plastic corrugated hose this will be blocked with fat limescale etc and needs cleaning it is a push fit with o rings pull out clean pipe refit and all should be well.also check holes on ends of spray arms are not blocked as they will not rotate but water will still come out
hope this helps
Jul 14, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Apr 14, 2009 | Siemens Dishwashers
Neff dishwasher
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Aug 07, 2008 | Dishwashers
Lower spray arm not rotating
rotation is only by water coming out of angled jets at end of spray arm. probable that these are blocked. take spray arms out and run water thro centre hole and remove whatever is blocking the jets - usually rice or sweet corn
Aug 05, 2008 | Dishwashers
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
41 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
