Question about Frigidaire FPHD2491KF Dishwasher
LO indicator light no other buttons work - Frigidaire FPHD2491KF Dishwasher
1999 chevy blazer 4x4 The 4 wheel drive dash switch is brand new. When in 2 wheel drive none of the buttons light up. When I push 4 hi the 4 hi and 4 lo button lights light up and seems to be in 4 hi. When...
It could be a junk switch or it could be bad contacts inside the transfer case motor.. Does the transfer case switch to the selected gears? Everytime? If so, you might try another switch. If it does the same, I would say the motor contacts are bad. Replace the motor if you want the lights, But I personally wouldn't do it until the motor quit switching gears. They're not cheap.
Nov 13, 2014 | 1999 Chevrolet Blazer
My 2002 gmc yukon slt wont switch out of auto fwd? It was working fine in 2 hi then i switched it to 4 lo the light on the 4 lo started blinking while it was still blinking i accidentally hit the auto...
You need to replace the lockup servo mounted in the front differential housing. the light will blink to indicate that the lockup servo is not engaging/disengaging. you can get the servo at a local parts place. It is very easy to replace and is easily accessible.
Mar 23, 2011 | 2003 GMC Yukon
Green indicator light on 1998 kia sportage
That light sounds like a differential lock or 4-wheel drive. This is usually found in 4-wheel drive and all-wheel drive vehicles. Being the light is "GREEN" and not amber or red tells me that it's not an abnormal problem.
Look around your dashboard or gearshifter for a button labeled 4x4 HI, 4x4 LO, 4x2 HI. sport/off road button, or a second, smaller shifter. Switch them around a little, and if it is a 4x4 selector, be sure when you drive on paved roads to have it set to 4x2 HI. 4x4 HI should only be used if you get stuck to help you get out (snow/mud) and 4x4 LO is only for off road driving (trail blazing/rock climbing/4-wheeling/mud bogging,etc.)
Also, check for any switches labled "DIFF LOCK" or 'AXLE LOCK". In most cars a green light is normal operations.
I hope I could help you find a solution to your problem.
Dec 04, 2008 | 2008 Kia Rio
Lockout mode
go to the channel you want to lock out with the manual (man) button, then press the LO button. and the LO on the indicator should disappear showing it is no longer locked out.
Oct 10, 2008 | Radio Communications
TV CODES
tengo un control remoto universal GH RC84912 nesecito los codigos l para un televisor philips me lo pueden enviar a mi correo danielesteban_30@hotmail.com de ante mano gracias
Dec 11, 2007 | GE JASRM24912 Remote Control
Frigidaire FPHD2491KF Dishwasher Logo
49 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
