Question about Water Filters & Coolers
Contact grill will not turn on - Water Filters & Coolers
My outside knobs wont turn and yes i pushed them in before turning.
Nothing odd about that grill. Spray with WD40 after removing the knob, and also the rear behind the front panel. It may just have stiffened up. If that doesn't work, contact Costco direct.
https://www.costco.com/Signateur-5-Burner-Grill.product.100382501.html
Feb 22, 2018 | Grilling
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
One of the small wheels came off the grill as I was pushing out of my garage. The grill rolled on its back. I put the grill back upright and now when I plug it in and turn the digital dial it says...
Instead of taking it back to the store, which I don't think will solve the problem. As, it's not really a warranty issue. Contact Traeger Industries Technical Service Dept 800-872-3437 for a solution to the Error Code.
Apr 13, 2011 | Traeger Industries BBQ075 All-in-One Grill...
I have a gas leak coming from grill, gas is turned off. Is this a common problem and is it a simple fix?
If you still have a leak when the gas tank is turned OFF, it's not the grill leaking it's the propane tank valve leaking. Carefully disconnect the hose from the grill (No Smoking) and move the tank as far from the house as you can, into an open area, where the gas can dissipate. Propane gas is heavier than air, it doesn't rise it falls. If after doing this and you still smell gas leaking from the tank, contact your local fire department.
Apr 06, 2011 | Broilmaster P4BL Gas
I have a Dimplex electric grill like the BPC one and it won't come on. Plugged in and nothing happens. It was purchased late summer 2010
If you still have your Proof of Purchase, it's still under warranty. Contact Dimplex USA, Customer Service at 800-668-6663. If you don't have your Proof of Purchase contact Dimplex USA, Technical Service at 888-346-7539. But, before making any calls, check the receptacle that the grill is plugged in to, to make sure it's functioning. If it isn't then the circuit breaker for that receptacle has been tripped and needs to be reset. Reset the breaker without anything plugged into the receptacle. Then plug the grill back and turn it on in to see if it tripped the breaker. Often times, the receptacle itself can be at fault and may need to be replaced.
Hope this helps your solve the problem.
Mar 19, 2011 | Dimplex BPC-2007 Electric Grill
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
Hotpoint eg76x grill
If the grill is working in some positions on the switch but not in others it sounds like the switch under the knob may be the problem. Does the same switch control the fan? If yes I would say you will have to replace that switch and that the contacts more than likely are worn inside the switch. Switches are usually not hard to replace and usually have lugs or a push/pull connector. Make sure you TURN OFF the POWER before you start trying to remove it. Hope this helps.
Regards
Bryan
Feb 17, 2008 | Ovens
Ionic breeze 3.0 repair
My Ionic Breeze GP began losing power occasionally but I could shake it and get it to turn back on. It got worse and worse until it would not turn on anymore.
The problem on mine is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
On mine, it appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
The following URLs describe the switch, but I have not found a retailer that carries it:
http://www.dicgroup.com/pdf/SM/SM5-01N.pdf
http://www.dicgroup.com/e-pro01-sm.html
Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
If I cannot find a replacement, I am thinking of either bypassing the bad switch entirely or swapping the switch from the back. Either way would defeat a safety feature so it's probably not to be recommended, but I consider the sacrificing the switch for the back cover to be introducing only limited risk, so I might take that route if I have to.
Nov 12, 2006 | Sharper Image Ionic Breeze 3.0 Air...
Water Filters & Coolers Logo
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
