Question about Fisher and Paykel GWL11 Top Load Washer
Lights on 3,4&8 also beeping as soon as u turn on
Fish
  • Fisher and P... Expert
  • 555 Answers
That is fault code 49
49. (00110001)
Cold Valve Coil Faulty
The Motor Control Module has measured a voltage
from the valve diagnostic circuit that indicates the cold valve is faulty.
The most likely cause is that the valve harness has not
been connected correctly or the valve is open circuit.
See fault 48 for service procedure.
48. (00110000) Hot and Cold Valve Coil Faulty
The Motor Controller module has measured voltages
indicate both the hot and cold valves are faulty.
harnesses have not been connected correctly
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Check the valve coils are not faulty (open circuit).
Tertiary Source: Motor Controller module.
Action: Replace the Motor Controller module.
Posted on Apr 20, 2014
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Not loading game or reading disc
The firmware that sony released in 2.6 is the cause of this it makes the laser burn more than it should by corrupting the laser drivers. If your diode is not burned out yet then this should fix your problem.
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Leave positive feedback
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
I can't set up my playstation 3 to my . The lead what goes to the back of my tv is not working. As soon as turn on my ps3 nothing comes up on my tv
Please try this following solution :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 22, 2010 | Sony Playstation 3 (PS3) Console
I turned on my ps3 and nothing is happening it is not giving me the option to sign in or anything. just the blue backround nothing else and now it wont let me turn it off.
Sounds like you PS3 software has become corrupt. Follow these steps to sort it but I must warn you, you will lose all your save games!!
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later then beep once more and turn off. Release the power button when it turns off.
Step 3. Press and hold the power button again. It will beep as soon as you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. As soon as you hear the two beeps let go of the power button.
Step 4. Your PS3 will now boot into recovery mode. Connect you controller via USB when asked and press the PS button.
Step 5. Select option 5 from the recovery menu, "Restore PS3 system". This will rewrite your PS3 software and hopefully should sort your problem.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
I can't get the light or the bell to stop flashig or ringing on the berkley pole tap.what do i do?
You MUST have the LED light facing down towards the reel when it is attached to the rod. If it is attached upside down with the LED facing up it will continue to flash or beep nonstop. The simple instructions for the Berkley poletap is -
1.Turn the unit to light or sound.
2.Cast your line,( it will blink or beep as you cast).
3. Set unit in rodholder or against chair,(Poletap will blink or beep about 12 seconds and then stop when still).
4. When a fish nibbles or strikes the poletap will alert with your setting of light or sound.
You may want to check out the new Berkley Poletap Pro, It has complete sensitivity settings for windy days and Tilt - angle for slow pull fish, high current and trolling mode.Awsome product!
Check it out at this Berkley site.
http://www.berkley-fishing.com/prod.php?k=299309&sk=299309&p=PURBAPPBA%20(11187809)
Oct 04, 2009 | Berkley Twist Lock Rod Rack
My ps3 is not reading my games
My ps3 didnt read my ps3 games..followed these instructions and it worked!!
http://boardsus.playstation.com/playstation/board/message?board.id=ps3updates&thread.id=52730
Thanks to Krazyfox
Apr 19, 2009 | Sony PlayStation® 3 (80GB) Console
Hi when i turn on my ps3 corrupt data comes up on screen and when my ps3 trys to fix the problem it just goes back to the start again i cant even get into the main menu its 2 years old was kept like new i...
Try this and get back with me, I will look into it for you.
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
When I try to turn on my camera (Samsung Digimax S500), it beeps 3 times.
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Apr 20, 2008 | Samsung Cameras
Fisher and Paykel GWL11 Top Load Washer Logo
55 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
