Samsung AQV24NSGN red and green light blink
It turn on for 5 min then green and red light blinking and turn off split unit
SOURCE: ALL LIGHTS BLINK BUT UNIT IS DRAINED
Hi all,
I think the problem is that the A/C has tripped the electrical switch located in the plug. To correct press the black button followed by the clear button. Then try turning the unit on -it has worked for me so no reason it should not work for you.
Regards,
Tommie C.
Posted on Sep 02, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
daniel719
  • 240 Answers
SOURCE: TV turns itself on and off, Green light blinks
lamp and thermistor needs replacing.
Posted on Jan 14, 2009
SOURCE: sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
Posted on Mar 01, 2009
  • 92 Answers
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
Posted on Sep 07, 2009
Mitsubishi split ac indoor light blinking unit not working
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 06, 2015 | Mitsubishi Heating & Cooling
Have a Sanyo KS2472 split inverter unit. On turning it on, operation light blinks and does not cool. Also compressor does not seem like it turns on outside. Please help.
Jun 06, 2015 | Sanyo Heating & Cooling
Pn43d490 clicks blinks red light twice and will not turn on
do you have a dim screen? if you put a torch to the screen at an angle can you see the picture?if so this means the backlight is out, it could be the inverter board or the bulbs themselves though this is unlikely.do you get the 24Vgoing to the backlight from the psu?
Dec 09, 2013 | Samsung PN43D490 3D Plasma TV
When I turn on the unit I get a green light, but after about 5 seconds it switches to red blinking and I do not get a screen
What is the model of TV?
The Red blinking light is a Protection Error Code. Your Tv needs repair. Most common is the power or Main Unit / Logic Board.
Post your model and how many times the light blinks. Also try unplugging for about 20 min and see if it will turn on.
Some models you get lucky and its a common problum which makes for an easier diagnosis.
Check
RNS-Systems.com
for general pricing on LCD and Plasma TV parts.
Oct 14, 2009 | Philips 42FD9954 42 in. Plasma HDTV
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
