Question about Baxter BXA2G Stainless Steel Gas Single Oven
No ignition for flame call - Baxter BXA2G Stainless Steel Gas Single Oven
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
How do u light the oven
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Ovens
Single wire igniter that sparks the oven on but flame goes out after a few seconds. Does the igniter control gas valve?
Its the other way around the valve controls the igniter so to speak
GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 23, 2015 | Ovens
Zanussi gas cooker gas not coming through no ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
Jul 30, 2014 | Zanussi Ovens
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
Frigidare gas oven wont ignite
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
Oven not working
GAS OVENS
Nov 22, 2013 | Belling Ovens
Diplomat adp 0511 grill has no gas or ignition
I offer free advice bcuz God is so good!
GAS OVENS
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Having problem with the bake igniter not always igniting. Hear clicking, but no flame. Doesn't happen all the time.
You may have a weak igniter or a bad safety valve depending on the model. Let me explain. Their are many different types of oven valves. Some use glowbar and others use standing pilots, still others use a igniter with a safety valve and flame detecting switch. So you do not have a generic problem. To get a specific answer I will need the model number. Since you say you hear the clicking I am gonna assume that is a standing pilot with spark igniter nd safety valve/flame switch. In that case you either need to replace the valve if it is a combination one with thermocouple and valve all in one package or the flame detecting switch if your model has indeed a stand alone falme switch I have some repair photos: HERE
Jan 22, 2010 | Kenmore Ovens
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
Baxter BXA2G Stainless Steel Gas Single Oven Logo
Top Baxter Ovens Experts
Owen Barnes
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a Baxter Oven Expert? Answer questions, earn points and help others
