Question about Binks Air Tools & Compressors
Binks 35 manual - Binks Air Tools & Compressors
My binks 2001 will not pick up paint under 60 psi, and at that must be very thin!
I think I would 1st check to make sure the fluid nozzle is not leaking (sucking) any air. There may be a small piece of debris between the nozzle and body causing it not to be completely sealed.
Another place to check would be the pick up tube to the main body.
If you don't have one, here's a link to the manual for your spray gun.
http://www.binks.com/Portals/0/repository/77-2626.pdf
Hope this helps.
Jun 14, 2014 | Binks Air Tools & Compressors
I bought a binks bbr with a tip of 97p . don't know what the 97p stands for. wanted to know if you guys knew this answer. I'am thinking it could be the needle size? your answer will be greatly...
The 97P stands for the Air Cap. For the BINKS BBR (or Mach1A) are more than ten different air caps available which differ in air flow capacity and pattern width. The 97P has an air volume of 21 SCFM (@10 PSI) and a pattern width of 16" (if sprayed from 10" distance).
Michael
Jun 14, 2011 | Binks Spray Gun Bbr Auto Hvlp Auto Recirc
DeWalt charger #DW9107 binks eraticly, even when battery is not installed, DC output is 35 volts, which is too high, the reading across all of the diodes on the circut bd in the converter circut is 5.8...
There could be a number of things wrong inside the charger, and could cause more problems trying to replace components on the board. Your best bet is to look on ebay or some other place to see if you can get a replacement charger.
Mar 29, 2011 | Dewalt DW056 18 Volt Cordless Impact...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
I need a users manual for a binks model 15 spray gun
Here you can find a manual: http://www.tpub.com/content/automotiveaccessories/TM-9-4940-507-14-P/TM-9-4940-507-14-P0006.htm
Michael
info@bsc-teknik.com ' www.bsc-teknik.com
Jun 14, 2010 | Binks SPRAY GUNS & OUTFITS
Spares for binks 630 spray gun
You can find spares for Binks 630 here: http://sprayfinishingstore.com/products/spray_gun/classics-gun/binks-630-gravity-spray-gun/
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Sep 29, 2009 | Binks Air Tools & Compressors
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Air Tools & Compressors Logo
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
Rick Amick
Rick Amick
john h
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
