Question about Nordic Track Exercise & Fitness
T25 console not light up - Nordic Track Exercise & Fitness
Cabin air filter installation 2006 volvo s-80
remove the passengers side lower kick panel, it's under the glove box. it has two T25 torx screws.
Disconnect the light and move it out of the way.
You'll see a large black cover underneath the whit a/c case. The black cover will have four T25 torx screws. Remove all four screws and the cover will come off.
remove the cabin filter by pulling it through the bottom.
pay attention to the orientation of the filter. it will only go in one way.
Reassemble the same way you took it apart.
Mar 15, 2014 | 2006 Volvo S80
I have a Model T25/2ED timer. Product #TN004000 I need to know how to program it?
I have the user instructions for the selecttime T25/2ED in Dutch and French in pdf format.
Contact me at andre.peeters3@telenet.be and I'll send it to you
Dec 28, 2010 | Vacuums
Loading T25 staple gun
Sounds like the slide and the spring and the snapin end are missing. Your local hardware store may have one or can order one for you. Take the tool with you so they can tell whats missing.
May 21, 2010 | Arrow T25 Staple Gun
VW T25 CU engine is it a type 4 or type 2 (year 1981)
Hello! It's a type 4. Aircooled flat 4 (boxer) engine fitted to T25 vans from 1979 to 1983.
Nov 03, 2009 | Volkswagen Camper Cars & Trucks
Where is the cabin air filter located on a 2006 S60 and what is the replacement procedure Thx
Remove the passenger side kick panel (where the little light is above the pasengers feet) it is held by 2 T25 screws, pop down the front edge and angle it out. Then you will see a black panel on the bottom of the airbox held by 4 gold color T25 screws, remove those and pull out the filter
Aug 12, 2009 | 2006 Volvo S60
TRYING TO FIND OUT WHY MY GEARSHIFT LIGHT IS NOT WORKING AND IF ITS MY BULB I WOULD LIKE THE LOCATION ITS A1995 VOLVO
It's almost always the bulb.
Remove the coin holder. Under it you remove the T25 torx screw then remove the cigarette lighter. The other T25 Torx screw is under it. Remove the front small console and unplug the 2 wires to the lighter and pull the light straight out.
Located down below the holder will be 2 T15 Torx screws, remove them. Down inside where the 2 T15 Torx screws are (down in the botton) there are 2 large wire connectors remove them both. They just pull out from their sockets.
Open your center console arm rest and remove the cover on the bottom, you will find 2 T25 Torx screws there. Remove them. Set the parking brake, so the handle is as high as you can go. Remove the little plate that sits under the parking brake, it should just pop out. Lift the rear of the arm rest and pull the console out at about a 45 degree angle.
Now you can reach under the gear shifter plate and pull out the bulb. It is on the left side of the shifter and has two wires going into it. If I remember right they are pink and black. You will have to get the bulb from the dealer. Then reinstall in reverse order.
Hope this helps.
Jul 16, 2008 | 1996 Volvo 850
Exercise & Fitness Logo
15 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
