Question about Foxconn G41MXE Motherboard
No Display No Beep Sound, No Display, also removing parts out side,,,
  •  Mike M
    Mike M Apr 13, 2014
    Hi Weligama Leadcom, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
If you are testing the motherboard by removing items plugged into it, remember to leave the CPU Heatsink on if the CPU is still in the socket otherwise the CPU will overheat in seconds or minutes and could be damaged.
If you power on the system, do the fans spin? such as the CPU heatsink fan? If no fans are spinning that are connected to the motherboard, see if the fan is spinning inside the power supply using a flashlight if needed. If not, try a known good power outlet or different plug on your surge bar or a new surge bar.
Even if the power supply fan is spinning, the power supply could be faulty. Borrow or buy one that matches the current wattage written on the side (ie: "output 350W")
Post back here with more info or if anything of this sounds like the issue you are having.
Posted on Apr 13, 2014
No display, klikking sound from relais and motor is shocking light beep sound from speaker
I had the same thing happen to me, it turned out the the power supply failed. It is located on the right side of the printer. There was a capacitor that blew. After replacing the capacitor the printer started up just fine. You will need to remove the right panel and replace the capacitor. Hope this helps you.
Jan 06, 2011 | Samsung CLX 3160fn All-In-One Printer
Verifying DMI pool data
Possible main memory fault; swap memory modules if you have more than one installed. Otherwise, clear the CMOS contents in the Bios and re-configure. ( remove the coin battery and short circuit the battery socket contacts then re-install the battery )
Jan 25, 2010 | Biostar Computers & Internet
Installing memory but no display, if i remove the memory i get beep sound
if you get the beep sound is very good because in this case you know the motherboard is good. try replacing the memory and make a memory test with memtest.
Dec 08, 2009 | IBM ThinkPad T41 2373 Notebook
There is no beep sound no display
Try to reseat or replug first your memory. Or clean its connecting terminal with a soft gel eraser, both side. But do this when unit is off and unplugged to wall socket.
Some motherboard do not send beep sound when memory is at fault, and also no monitor display. Usually no boot up. But CPU processor fan and hard disk LED is turn on or running.
If reseating and cleaning doesn't help try to swap another good memory card with same size for sure. Other than that suspect other component. Second in line is video problem and some other component.
Sep 25, 2009 | PC Chips Computers & Internet
When start on asus motherboard 1beep+1beep sound total 2 beep sou
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Jun 19, 2009 | Intel Motherboard
No display in a board
hello
the beep is due to ram
try to remove ram and insert again while power is off
Nov 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
Re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Jan 16, 2008 | HP OmniBook XE3 Notebook
Troubleshooting
are u getting any beep message ? let me know the model and the beep tone that you get, if you don't get any beep try changing ram if you have VGA card installed try changing that.
Dec 06, 2007 | Compaq Presario SR1000T (568657) PC...
1 yr old and Stopped working
the beep sound means that there are ac voltage in the unit but you gona need a tech there is no removal parts in that board and sound as a bad ic is there..good luck
Aug 05, 2006 | Kenmore 54701 Dehumidifier
Foxconn G41MXE Motherboard Logo
130 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
