Question about Brother CS-6000
Sewing machine wont feed thread - Brother CS-6000
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
Zenqi
  • 208 Answers
SOURCE: needle not grabbing the thread
Place a new needle in the machine with the flat side to the back.
Raise the presser foot.
Turn the handwheel until the take-up lever is at it's highest position.
Set the top tension to 5.
Re-thread the machine.
Posted on Oct 01, 2009
  • 1116 Answers
SOURCE: Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Posted on Feb 24, 2010
Jimsta01
  • 405 Answers
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
Posted on Mar 30, 2010
My singer simple; the wheel is difficult to turn, the needle wont go up and down, the material wont feed
Sounds like you have a thread jam( bird's nest) inside your bobbin housing. Take the face plate off, remove the bobbin, and take the housing apart if you have to...then start all over with winding new thread on the bobbin and re threading the machine before you try sewing. Hope this helps!
Dec 03, 2016 | Singer Sewing Machines
I have a 513 machine the bobbin thread wont let the needle pick up the thread.
it is very possible that the machine could be out of time & it would have to be retimed at a sewing machine shop
Feb 26, 2012 | Sewing Machines
Presser foot will not feed and the thread wont catch
The presser foot is not suppose to feed. It's purpose is to hold the fabric in place as the feed dogs feed the fabric from the front to the back of the machine as stitches are formed.
Check the needle to be sure it is installed with the flat side of the needle shank facing the back of the sewing machine.
Refer to your manual to be sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the guides.
Pull the bobbin thread up by lowering the threaded needed down and then back up. Pull both threads under the presser foot and to the back of the machine.
Set the stitch length to 2.
Place a scrap of fabric under the presser foot. Holding onto the ends of both threads, lower the needle into the fabric for the first stitch.
If the machine still does not stitch, the machine may need to go in for maintenance as the timing may need to be adjusted.
If the feed dogs are not moving, this also needs to be repaired by sewing machine service tech.
Mar 29, 2010 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread wont pick up
Refer to the manual to be sure the bobbin is feeding the thread in the correct direction.
Mar 25, 2010 | Singer Deluxe 57825 Mechanical Sewing...
My prdect is fashionaire 2380.when i'm sew somthing it's break the thread,and it's stack
Check the thread spool to see if there is a nick where the thread is catching. If there is, you can smooth away the nick with an emery board, or just flip the spool so the thread is feeding from the bottom of the spool.
Sometimes the thread feeds too quickly from the spool and puddles around the spool pin. A thread net (can be purchased online or at a sewing machine dealer) can eliminate this.
Check the threading to be sure it is correct - always thread to top thread with the presser foot up.
Check the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Refer to your manual for threading and bobbin position.
Feb 20, 2010 | White Sewing Fashionaire Sewing 2380...
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
I have a Necchi 537L it was sold as a comercial machine that could do leather. Mine wont do soft paper! Whats up?
This is not a commercial machine and will give you trouble trying to sew upholstery,especially if you use heavy upholstery thread. You will get loops on the bottom.
It will sew only short stitches,No matter how long the stitch length is, because it only feeds the fabric from the bottom and it will stick.
It should sew regular fabric with normal threads with no problems. There is a pressure adjustment on the top of this machine which may be where your problem is located.Look in your book for instructions.Also, make sure the feed dogs are in the highest position. I don't know how long you've had the machine but if it has been awhile,remove the needle plate and clean the lint out from between the feed dog teeth.
sewman7
May 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Bobbin wont feed
a. needle in backwards
or
b. needle threaded wrong
Apr 24, 2009 | Sewing Machines
Brother CS-6000 Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
