Question about Miele W310 Front Load Washer
Machine won't switch on
Machine is plugged in but not lights are on the machine, Its as if there is no power but have checked the Powerpoint and its working fine. Used the machine yesterday and everything was ok
3 Suggested Answers
  • 2976 Answers
SOURCE: washing machine w827 drum fills when the machine is switched off
Before you replace the valve, try to back flush it. It may allow you to run water through it from both directions and clear the obstruction. That wil save you the cost of a new valve. Also, get some inlet hose filter screens. They go into the supply hoses, with the narrow pointed end toward the water supply.
Posted on Feb 05, 2009
  • 6277 Answers
SOURCE: The on/off switch has stopped working - unable to
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid, main motor, drain motor etc..
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 01, 2011
Washing machine why does my whirlpool WFS1274cd have no power?
have you checked the fuse and the wire for any damage first
Jul 30, 2014 | Whirlpool Washing Machines
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Brothers sewing machine
first check the outlet to see if it works
next check to make sure the power cord is plugged into the machine
correctly.
if you've done the above things, & you push the switch to turn the machine on & it still won't come on, then the machine needs to be
checked.
Sep 05, 2012 | Brother Sewing Machines
No display when switched on
Are there any lights on at all also you can reset the machine by unplugging for 5 mins and plugging back in making sure power is on and press power button on machine it should light up. check the fuse could help if no power. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
DRYER WON'T TURN ON
first check the power to the machine itself,, plug in a light or something to make sure you have power, if thats ok, remove the back of the machine, and check for power ( with a meter) into and out of the thermal fuse, you can see one here,, and also a door safety switch and other pics to check,, http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Good Luck feel free to contact me if you need more info
Jun 18, 2011 | Kenmore Dryers
The unit will not run.
Check cord on machine. Plug in and turn on wriggle cord near powerpoint and then near machine and all over, if it starts and stops the cord needs replacing
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
No hot water
I guess you have check the settings on the machine.
So I am guessing possibly the acuator (electric) that switches the hot water flow on and off and being initally controlled from the timer circuit. Both hot and cold have actuators. These are usually what the flexible hoses screw into. The will have connections on them inside the machine.
You need to have the machine looked at.
WARNING
If you tamper with or check the wiring yourself, ensure the plug is removed from the powerpoint.
You can still get an electric shock of the neutral wire if it is plugged in, even if the powerpoint is turned off
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Miele W310 Front Load Washer Logo
56 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
