Question about Makita Saws
MAKITA DPC 7311 PLUG GAP - Makita Saws
4 Suggested Answers
  • 3 Answers
SOURCE: Whats the mix for a
50:1 synthetic... one 2.8fl oz bottle per gallon of regular gas
Posted on Nov 30, 2010
  • 509 Answers
SOURCE: Ive got a Makita concrete
The manual says to mix it 100:1 if using Makita high performance oil or 50:1 using regular Makita 2 stroke oil. I'd go 50:1 with non Makita oil too.
Here is a site to download a pdf manual if you need it.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Feb 18, 2011
  • 396 Answers
SOURCE: can I check my makita dpc 7311 coil with a meter
You can check the coil to see if it is open with a multi meter set for Ohms. However, If the insulation of the coil is breaking down your meter may not be sensitive enough to detect this failure. You would need a Z meter to Identify problems and the value of the coil. I believe it would be in you better interest to go to an auto parts store and buy a test plug which is no more than a spark plug with a ground clip on it. You can remove the plug wire on your saw and connect it to the test plug. When you try to start the saw you should visually see a spark from the test plug. If you do then your plug should ignite the fuel. If you do not then you will need to check the plug wire and the input to the coil.
Posted on Mar 30, 2011
My makita dpc7311 has no spark, replaced plug, coil, flywheel, what else can it be
Check the ground wire from the coil all the way to and including the contact point at the choke switch. I've encountered a couple where insulation was worn off or the wire was pinched and making contact with the head, carb or other metal part and grounding out the coil.
Sep 02, 2013 | Makita Dpc 7311 Concrete Saws
Spark plug gap for makita dpc 7311
take the cover of a pack of cigarette paper then its most of the times right.
Feb 24, 2012 | Makita Saws
Can I check my makita dpc 7311 coil with a meter
Mar 30, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
Ive got a Makita concrete saw DPC 7311,it says a mix of 100:1 but thats alot ?
Feb 18, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
Whats the mix for a two cycle dpc 7311
Nov 27, 2010 | Makita DPC7311 73cc 14Inch Gas Powered...
Have a makita quick cut saw but site requirements need a manual. can you email me a copy?? Machine is Makita DCP 7311 concrete cutting saw
go to Makitatools.com and type in your model number which is DPC7311 and you can download the owners manual for this tool. If I have helped with your request would you please rate this response accordingly. Thank you
Feb 11, 2010 | Makita Saws
No operators manual for makita dpc 6410 petrol disc cutter
Come on, it tooks me 20 seconds to find it...Web search is all about keywords. makita dpc 6410 manual leads to the answer. Adding pdf would have been even better...
Aug 01, 2009 | Makita DPC6410 64cc 12" Power Cutter
Saws Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
