Question about Ovens
After silver cover is removed, a black plastic piece remains. When I try to pull this out, a surrounding piece of metal on the outside also stats to come out. Should this happen or should the black plastic piece slide out from the surrounding metal shealth? how much force do I use to remove it so I can attach new knobs. Have checked suggested website but it would not open. Thanks, Anne
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
  • 117 Answers
SOURCE: How to remove timing control panel on Gas Amana Range AGS746E
Here is a diagram of your stove console. Make sure you remove the nuts holding the switches to the console.
Posted on Feb 25, 2009
SOURCE: CHANGE THE LIGHT IN MIELE OVEN
Had the same problem. Ended up removing interior oven panels (sides first then top on model H310B). This is easier than you might think. Could then get a good grip on the light's glass cover and it unscrewed easily.
Posted on Sep 25, 2009
  • 2418 Answers
SOURCE: How do I remove the
Open the door about 3" this is the "vent heat" location. Lift up and out on the door, pay attention to the hinges and their position, so you can reinstall the door without any problems.
Posted on Nov 14, 2010
mc1bean
  • 3053 Answers
SOURCE: Jenn-Air Electric Convection Wall Oven--JJW9530--I
Hello, cfhiller
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
Can I reset Overheat on Blue SealTurbo Fan E314D without calling an engineer
I am not shore exactly Where the safty stat on that model is situated. Check right underneth the controlle box underneth the oven there should be a little round plastic screw cap looks like a fuse holder unscrew cap and press the reset button. If it is not underneath the oven switch off main power supply and open back cover on oven and look for safty stat (all though there is 2 types of stats )1st type is a square silver box with 2 or more electrical wires connected to it with a thin silver wire on it that goes into the oven baking chamber and it got a small red reset button on it just press reset button.2nd type looks like firs type but do not have a reset button this one will have a dial on it. "If it is 2nd type it can not be reset it needs to be replaced"but you can turn the dail and listen out for a click sound if you can hear a click sound it NORMALLY means the stat is still working and you got a nother fault somewhere if there is no click sound replace stat with one that got the same values as the original stat and make shore you set it the same temperature the original one was set on
Jun 29, 2015 | Ovens
Temperature probe icon persists on the display and cannot be extinguished. Seems to be locking out other oven functions. Tried removing power overnight - no change. Followed protocol to turn off "Sabbath...
If the probe is not connected, then the actual connector in the oven is faulty. If you don't use the temperature probe, you can take the front control panel off and disconnect the probe connector. I did this 8 years ago
Jan 10, 2010 | KitchenAid KEBC107 Electric Single Oven
How do you remove the door on a 4080 bm?
There are two metal clips at the bottom of the glass that hold the bottom of the glass in place- you can see these from the inside when the door is open and from the outside at the bottom of the door when the door is closed. There are two metal clips at the inside top of the door. You can see these when the door is open slightly inward from the "switch pins on each side.
Open the door. You will see 2 small (about 1/16") metal pieces about 1/2 " in from the 2 switch pins. CAUTION: WITH SOMEONE ELSE HOLDING THEIR HAND UNDER THE GLASS PANEL. Press the 2 metal pins in. Then slowly pull down on handle until the metal parts move down past the tiny opening on the black inner door. This glass is tempered and I can tell you from experience it will break in a million pieces if you are not careful tohold the glass.
It's delicate but very easy. Just be careful
Nov 23, 2009 | Miele DG 4080 Stainless Steel Electric...
Door remains locked
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Control panel buttons due not work
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
email me for pics schmidtkeith1@yahoo.com
Aug 31, 2009 | Maytag 30" Built-In Single Electric Wall...
Replace oven light
If the metal sleeve that the bulb screws into is damaged, you can go to a local appliance repair shop for a replacement. Be sure to unplug the stove before doing any work on it. you will need the make and model of your oven to make sure you get the right part.
In the future, if the bulb detachs from the base on any light you have, 1) disconnect the power, 2) using a small wooden dowel or the plastic handle of a screwdriver that will fit inside the base, apply enough pressure while turning to remove the base. Good Luck.
Aug 06, 2009 | Ovens
Built-In Oven Buttons Stop Working
Email me for some pictures:
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
