Question about Pool & Spa
Watertech presscontrol Pump will not start when tap turned on. Intermittent issue. Fine once going. Does it about once a day. To make it go, turn the power off, turn the pump by the fan on the end of the motor. Turn the power back on. It goes. No resistance when turning it by hand. Pump is not seizing up. Not sure if the watertech presscontrol system is not detecting the pressure drop, or if the pump is not starting for some other reason.
  • 373 Answers
SOURCE: 1993 Acura - intermittent fuel pump operation (no start)
HI...
The common cause of the problem that you related.
Is the FUEL PUMP RELAY " Called MAIN RELAY.
Is located : left side under the dash.
Is a BIG relay gray colour. with a connector of 7 or 8 wires.
I recomend replace the relay.
And letme know if you solve your problem.
I hope this information work on your problem.
Thank you for use fixya.
Posted on Jul 25, 2008
  • 1383 Answers
SOURCE: Air compressor w/5hp motor
Assuming that the motor is factory matched to pump, it should be powerful enough to turn the pump. Most problems with motors are related to pressure switch and/or capacitor. The pressure switch could have burned contacts causing low amps to reach the motor. The capacitor should test at least 90% of rated value printed on capacitor. Some volt meters have capacitor check setting. Also this motor at 5 hp must draw lots of amps. The outlet should be rated at least 20 amps and plug the compressor directly into oulet without an extension cord. \
Secondary problem is the in-tank check valve. The check valve should hold in tank pressure without leaking back to the head of the pump. If check valve leaks, replace it with any brand of same thread size. enjoy
Posted on Nov 29, 2008
  • 61 Answers
SOURCE: The pump motor hums, but won't start.
A humming motor usually means a bad starting capacitor, but it could be some other things. If you see some water movement that means that your impeller is spinning and the capacitor is good, and in this case you would want to check for air leaks on the suction side of the pump. Make sure that there is water at least 3/4 of the way up in the pump and the valves are in the right position (sometimes turning the skimmer off and just sucking from the main drain can help). Also check to make sure that there is water in the skimmer, and it is not getting sucked dry. Next lubricate the pump lid gasket, and try some silicone around the threaded pipe on the front of the pump. If all this fails you could have some debris stuck in the impeller.
Posted on Apr 05, 2009
  • 77 Answers
SOURCE: motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
Posted on Apr 22, 2009
daves944
  • 1050 Answers
SOURCE: Buick Regal dying
You have a problem in the fuel pump relay circuit for sure then. I'm betting the relay, but it could be that dropping resistor.
Posted on May 11, 2009
None start issue
check for alternator and starter motor functioning ok , does it turn over and not fire up or not turn over at all?
Mar 28, 2014 | 2003 Volvo S80
My 1997 chevy lumina will not start it just makes a clicking sound when i tr to turn te key
Sounds as if you have a bad starter. The vehicle running differently when cold is a whole different issue that has nothing to do with the starter. Below is a picture of the starter and its location. You can have someone turn the key as if to start the car while you actually touch the starter. If it is bad you will feel it trying to enguage or click inside. I'm guessing that's the clicking noise you hear. If the vehicle is in a bad location and you need to move it in order to replace the starter, again while someone is turning the key to start the car you can tap on it with a small hammer or something and GM starters are pretty good about loosening up and starting while you are tapping on it. This doesn't fix the problem it just will get you going so you can move it. This "tapping" works about 85 percent of the time on GM starters. Either way if you feel the starter trying to go with somebody turning the key, more than likely you are dealing with a bad starter. Hope this helps.
May 22, 2012 | 1997 Chevrolet Lumina
When I turn the key on and hear the high-pitched whining noise (it's not very loud), the bike starts. No noise, no start. It's intermittent. Failed once on the road. Took to the local Honda shop twice....
That would be my first guess!! If you locate the fuel pump you can try tapping on it and see if it becomes intermittant. Or if it isn't too much just go ahead and change it. Expecially if it left you stranded once already. Sincerely HDTV GURU JAY
Mar 25, 2011 | Honda Silverwing 600 ABS Motorcycles
Changed fuel pump and fuel filter, now x5 2002 won't start
1. use scanner to find out if there's trouble code.
2.. it's not clear if the starter (motor) turns as you try to start the engine, if not, check starter motor including intermittent (maybe) problem with the ignition switch.
3.if starter motor turns everytime you try to start: check the electrical ignition system: coils & spark plugs
Apr 30, 2010 | 2002 BMW 5 Series
Cars turns over, but will not start
fuel pump??? two ways to test one good, one not so good. fist, without cranking over the motor, have someone go and listne in the back where the fuel tank is and try and here if there is a whirring sound when the key is put in the on position. you might not be able to here it. second (have a rag handy) undo one of the fuel lines and see if there is any pressure going to it = if none = dead fuel pump. third way....if it is easy to access the top of the fuel tank where the pump is, do so. remove pump and see if it works. also, if its an externally mounted pump, gently tap it with a wrench on the outside of the pump casing...this an actually make them work for a short time.
Jul 11, 2009 | 2005 Chevrolet Tahoe
Won't start
What engine? 4 or 6. Do you mean it will turn over but not start?
May 19, 2009 | 1995 Honda Passport
2005 Ford ranger sdtarting issues
Bad inertia switch, I just had the same problem.
Sep 17, 2008 | 1991 Ford Ranger Supercab
Pool & Spa Logo
81 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
