Question about Frigidaire PLRU1777DS Stainless Steel Refrigerator
Fridge is not cooling at all. I hear the fan running though. Not sure where to start
  • 51 Answers
There may be more than one fan, one or more may be to circulate the cold air through the evaporator (the coils that get cold) and the other is near the compressor or the condenser if the fan beside the compressor is running and the compressor is not, then the most commen problem would be the compressor start mechanism. Something like an RCO410 or a smaller version is the RCO810 the fastest cheapest thing to do is buy one and put it on by following the diagram written on it. If the compressor does not start after that and the condenser fan is still running, you will need a pro to change out the compressor, unless you have experience you can't do that yourself.
Posted on Apr 13, 2014
  • Angela Bunch
    Angela Bunch Apr 16, 2014
    Thank you. After looking more, I see that there is another fan behind the condenser coils. Both fans work. The compressor is running and tests ok with the multimeter. I am not sure what else to check.
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Freezer works, fridge doesn't
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 27, 2009 | Refrigerators
Both Freezer & Fridge compartments not cooling
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath. If that don't work you may be low on freon change fan motor
Aug 12, 2009 | Refrigerators
My side by side whirlpool ref. doese not cool or freeze even though the motor continues to run.
If it is not cooling in either freezer or fridge and the compressor is running you are more than likely short of refrigerant which has leaked out. The leak needs to be repaired and the fridge recharged. If there is slight cooling you should make sure that the fans are operating and that you have airflow.
Mar 03, 2009 | Refrigerators
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Freezer does not cool while the fridge is up and running. what is the problem?
Neither the freezer or refer sections are cooling? Can you hear if the compressor is running (black soccer ball sized unit underneath)? Could be "stuck" in the defrost cycle (happens a lot).
Oct 21, 2006 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frigidaire PLRU1777DS Stainless Steel Refrigerator Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
