Phoenix Gold XS2300 Car Audio Amplifier Logo
A
Anonymous Posted on Apr 13, 2014
Lpf buttion on phoenix gold - Phoenix Gold XS2300 Car Audio Amplifier
Kris Michalsky
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 27, 2019
Kris Michalsky
Contributor
Level 1:
Answers
Questions
0
Helped
108
Points
LPF is typically Low Pass Frequency, it puts the amp in a state where only low frequency signals will pass thru to the speakers. LPL is for Low Pass Level control, that is used on PG products that have an LPL port. Using a phone style cable and a 50k potentiometer you can control the level of the amp's output.
1helpful
I have 4 rsd65cs Phoenix gold 6.5 components 4ohm stable & 1 06S10L74 kicker I want to run it at 2ohm. A lil overpower is fine as I can always turn down.what is the best Option 5 channel amp? Thanks
sounds like you need to get a 2nd amp for the woofer, then bridge the two amps but be sure to adjust the output mode to lpf for your woofer and hpf for the 6.5s. hope this helps.
Phoenix Gold M50 schematic needed
the entire schematic and owners manual can be found here:
http://narbi.free.fr/manuels/Amplis/Phoenix%20gold/M50.pdf
My phoenix gold xenon 100/2 keeps blinking and putting a loud buzzing sound into my speakers, it went into protect mode, whats wrong with her just got it.
More than likely a blown output transistor. Phoenix can send you a schematic for that if you email their tech support. Be careful if you decide to work on it yourself.
I have a phoenix gold ti 1000.2 amp.. this is such a great amp and its hard to find.. the problem is when the bass hit i thought i blew the amp.. no bass comes from the amp anymore but the amp turns on and...
are you sure its grounded good and are you sure the amp is on or do you know for sure its the amp not the sub to see if its the amp just just wire it to an old speaker not a subwoofer and be sure to switch the lpf off
3answers
Phoenix Gold Octane-R 15.0:1
PG won't release schematic diagrams. Are the burned components resistors? If so, what are their circuit board designations (Rxyz)?
Top Phoenix Gold Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Larry Ng
Larry Ng
ADMIN Andrew
ADMIN Andrew
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
