Question about Xerox Phaser 6120/YN Laser Printer
How do i replace toner cart - Xerox Phaser 6120/YN Laser Printer
  • 555 Answers
Hello my friend, If you want to change or remove then you can remove the toner cart from your printer by opening the printer cover once the printer cover is open then remove the toner cart. Thanks
Posted on Jun 18, 2009
Samsung ML-1666 blank printout
Dear
Pl. check toner cart. if its refilled then checke the contact point of the toner cart. Put a good toner cart. if problen not cleared replace the SMPS.
Thanks.
Dec 31, 2014 | Samsung Office Equipment & Supplies
Just replaced toner K and now says empty
You replaced the Cartridge with a OEM product or third party or a refill. if the last the electronic chip on the toner cart is still telling the machine the cartridge is old so refilling will never work replace the cart with OEM cart,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 27, 2014 | Konica Minolta Magicolor 4690MF...
Just now toner refil but low toer eiiow led flasing problem
Because there is a chip on the toner cart once the orginal toner goes the chip tell the copier its gone you can refill all day but it will not change replace the image unit /toner cart.
Mar 29, 2014 | Konica Minolta 1710587001 Toner, 1500...
Minolta 8650 problem c-2a01
loo like you replaced the cyan toner cart.. (with the machine powered off and unplugged) take a look inside the machine with the cyan toner cart out.. make sure that nothing is blocking the metal contacts or if there are dirty contacts. perhaps there is a piece of debris that is blocking the connection of the new toner cart to the printer. another thing to check is the contacts on the toner cart its self.
Jan 02, 2014 | Office Equipment & Supplies
End of life replace new card
Dear
The toner cart. has lapsed its life.
As there is a chip inside cart. which keeps record of the page count and toner percent used. when predefined percent consumed it indicates.
The replacement with new cart or replacement of the chip and toner powder resolve your problem.
Thanks.
Apr 01, 2011 | Samsung SCX4623F Laser All-in-One Printer
Hey replaced the toner cartiage and it is still saying replace tone
Sir is the toner cart third party? if so replace with org KonicaMinolta Toner CART.
Mar 11, 2010 | Minolta FAX2900 Plain Paper Laser
Display says toner out even with new cart. Setting new cart message in resets menu to yes does not work, selection reverts back to no. Customer is using reman carts.
A number of companies use a fuse that blows when the cartridge is low. If the fuse is not replaced, it will still say "toner out". The reman should have replaced it.
Jul 27, 2009 | HP LaserJet 4100 Printer
Error code 14 "no tuner cart"
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
May 06, 2009 | HP LaserJet 4 plus Printer
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Hp 4600 color laser leaking yellow toner. The carts are actual Hp carts. Any ideas? Had problem with reman carts in April changed to origianl - now happened again. Any suggestions
How to fix toner (Magenta) leak in HP4600...
I have read and tried everyone methods (dc controller, replacing toner, & adjust paper sheet type) of resolving toner leak. The answer to everyone's problem, is to " check & replace the the two black alienation plates (1.5" wide by 10" long, strips are vertical position, held by 2 phillips screws)" located on the back wall after removing all 4 toner cartridges. I found that the plate had cracked and didn't allow the toner to close properly. I temporary superglued the part back and order a new kit (Q3668-67925 $19.99 + s/h). Problem solved.
Sep 24, 2008 | HP Office Equipment & Supplies
Xerox Phaser 6120/YN Laser Printer Logo
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
