Question about Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music & Video Player ,Silver
Usb will not play
Plug into usb and it will not play
HOW DO I USE THE USB PORT TO PLAY MOVIES
Tom,
To be able to play movies stored on a USB device (it doesn´t matter if it's a usb pen, a usb hard drive, etc), you will need two things:
1.- The device where you want to play the movies must support the USB device that you're using (not all USBs are the same, and they can be formatted differently, too). So if when you plug it in, the TV doesn´t recognize it, use a different USB device.
2.- The movies that you put on the USB device must be palyable by your device. ie: your TV, BluRay, etc must be able to decode and play the movie format, and this can be AVI, DIVX, XVID, H624, QT, MKV, etc. Even if your device reproduces DIVX movies, if the movie is encoded in a weird format, it won't be playable. The fastest way to know is trial and error.
Feb 09, 2015 | Hard Computers & Internet
How to play movies from usb on sdvd6660
Copy any video file like AVI, MP4, MKV,WMV to USB drive, plug the USB drive and select USB and play it, should play movies
Oct 22, 2012 | Sylvania Televison & Video
I am wanting to connect a Gateway keyboard to a Dell PC but I need an adapter from female to male usb port. What adapter do I need? Will I need to download any software for this?
amm udont need an adapter, the keyboard once usb will plug right in,, if its circular,means its a ps2 port and you need ps2 to usb. No no drivers needed. Or usb to ps2 ,, depends on your needs, But all Usb are standarad stuff.
May 06, 2011 | Dell Computers & Internet
I purchased a U-VIDEO USB video camera (The Sharper Image) and took it on vacation. I am attempting to upload the videos. Step 1 is Select Video, plug camera into USB port, Open the YouTube Video...
Keep it simple- download vlc player which plays EVERYTHING. Plug in your camera to usb - start player - direct to usb device and play back.
That file you are looking for should be in your programs directory.
Aug 25, 2017 | Video Cameras
Cant get my ipod touch to play when using my special audio cables i thought it was plug n play
Yes,if ur ipot touch is have plug and play and video capability.Use the HDMI cable.Plug the HDMI cable in one side to the ipot to the USB port hub,the other side to the tv USB port hub.The ipot should,work fine.
Sep 13, 2010 | Mitsubishi WD-65731 65" HDTV
Plug and play controller usb does not recogninize
Pls check that the USB controller and Plug and Play mode are enable or not in your system BIOS.If not pls enable it.and select Legacy USB support in Auto mode.If still issue coming then connect the USB device in another port.
Nov 18, 2009 | Video Game Consoles & Games
USB Port
USB port is used to plug external devices such as pen drives and other supported devices.. first of all there exist two usb ports: 1.0 and 2.0 . so when you connect your devices via usb, make sure that you have the 2.0 port for faster transfer rate.it is also a way to add more devices to your pc without having to unscrew anything.there are plug and play devices and non plug and play devices which require specific driver
Oct 19, 2008 | Computers & Internet
Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music & Video Player ,Silver Logo
20 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
