Question about Garden
Browning of lime fruit
Some of the fruit is developing brown patches as they ripen
  • 14 Answers
SOURCE: ThickToasted Sandwiches not browning or cooking on the bottom
There are a number of possibilities. First clean the cavity with approved non-caustic oven cleaner. Do not overuse this chemical. You need to remove all the crumbs at the back of the cavity. Use a putty knife if you have to. Check error codes by turning oven off and pushing 4 & 6 on the keypad at the same time to check for errors. These ovens are not like any other oven. You can't just guess and change parts. Its about like telling someone how to fix their own plane and hoping it works.
Posted on Jul 31, 2008
  • 21 Answers
SOURCE: told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
Posted on May 02, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Part of the screen has developed a brown color,
sorry! you have the famous nvidia video chip failure
see: HP.com and, see if you can get a warranty repair or, join the class action suit against HP and, Nvidia for their crappy chips
google the HP Nvidia video chip screwup
Posted on Sep 01, 2009
  • 788 Answers
SOURCE: samsung syncmaster flat screen monitor brown patch on screen
If the warrany was not repaired the first time correctly, you may have the company refund your money under the lemon law.
Posted on Sep 11, 2009
  • 10865 Answers
SOURCE: I recently purchased an Electrolux
Hello Patricia. So sorry for your trouble. Based upon your excellent explanation of the issues, it is likely that you have one of two possible causes.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem. Joe Thanks for choosing Fixya!
Posted on Nov 23, 2010
I HAVE CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP
Have a read. Disease, pests or virus.
Grape Diseases and Drying on the Vine ' Home Guides ' SF Gate
homeguides.sfgate.com > Garden > Pest Control
  1. Cached
  2. Similar
The leaves become mottled with tiny black spots and the fruit also bears dark spots. ... Most of the diseases that cause drying grapes on the vine are fungal ...
Why Are the Grapes Dying on the Vine? ' Home Guides ' SF Gate
  1. Cached
  2. Similar
Luckily, the fungi, insects and bacteria that cause fruit to rot or wither are easily ... Summer bunch rot-infected grapes have black, brown or green powdery fungal ... Removing leaves at the base of stems once grapes have set helps control both ... Best Time to Pick Concord Grapes for the Best Flavor ยท Grapevines & Leaf Curl ...
What Are the Causes of Grapes Turning Black Before They Ripen ...
  1. Cached
  2. Similar
If your grapes turn black on the vine before they ripen, the cause is usually black rot. ... which helps prevent infection by speeding the drying of leaves and fruit.
Why are my grapes turning dark and drying up before they ripen ...
https://ask.extension.org/questions/199835
  1. Cached
  2. Similar
Jul 16, 2014 - Minimize black rot problems by removing infected fruit, cleaning up mummies, and pruning out leaves that surround fruit clusters. See fruit links ...
Grape Diseases ' Integrated Pest Management Program - MSU IPM
www.ipm.msu.edu/grape_diseases
  1. Cached
Oct 16, 2014 - Leaves develop numerous dark brown spots, 1/25 to 1/5 inch (1 to 5 mm) in diameter. ... resulting in distinctive clusters of dead vines within the vineyard. ... Berries that do not fall off shrivel up, similar to black rot-infected berries. .... This disease occurs only in Concord and Catawba grapes in Michigan.
CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP Google...
Aug 14, 2017 | Cooking
Ripen cut cantaloupe
Not once it is cut. To test before cutting press the ends or smell the fruit, it should smell sweet. To ripen. put in a paper bag with a ripe banana as they give off ethylene gas which is a ripener. Also works on tomatoes.
Jul 01, 2017 | Cooking
Lemon tree fruit won't ripen
A lemon is a fruit that needs plenty of water, heat and food. Give it a dose of Epsom Salts 1/2 teaspoon to a gallon of water over a period of time and keep it warm. They should ripen with the right climate.
May 05, 2017 | Garden
What spray can I use to protect my pomegranates from fruit fly?
traps and baits
and or net bag the individual fruit clusters
Nov 03, 2016 | Cooking
Ripening fruit how do I get peaches to repine
Put them in a brown paper bag. It will make them ripen quicker.
Hope this helps.
Bob
Jul 05, 2014 | Cooking
Avocado puree
Lime juice must be added to prevent browning.
May 26, 2014 | Cooking
How to ripen apples
I have never had to do this but, I have heard placing them in a brown paper bag will ripen them.good luck.
Jan 20, 2014 | Cooking
Spots on tomatoes
If the spots are mostly at the bottom of the tomato, more like one blotch, it is from not having enough lime in your soil. It is called bottom rot.Putting lime in the soil is called sweetening the soil with lime.This is what you need to do for bottom rot. If it is in other places and more than one spot, it could be from insects crawling on and defecating on the tomatoes or maybe a type of fungus or mold. Hope you only need garden lime. It will save your tomatoes from bottom rot since it is early in the year.
May 30, 2013 | Garden
My plum tree starts producing plums they start off green then turn yellow and drop off
Lack of pollination or brown rot could be the cause.They are generally not self-fruitful meaning they need a different plum and often a specific variety for pollination and fruit development. If the plums were not full size and lacked a seed (stone) this was the problem.If not try a general fungicide.
May 13, 2011 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
