Question about KitchenAid 30 in. Slide-Out Ventilation Hood
Kitchenaid slide-out vent hood fan will not turn off
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Removing blower motor
tap the fan on the shaft just a bit then clean the shaft with sand paper then carefully pull and rotate the fan off of the motor shaft = lock the motors rotor in a vice this make it a easy job. BUT don't damage the fan ! if it feels like it's not going to come off STOP. and search for you local electric motor repair shop with free testing. and ask him to pull it off fer ya, ask him how to oil this motor so you don't go threw this again. ?
Jay the pool pump motor repair guy in longwood Florida 32750
Feb 08, 2014 | KitchenAid Kitchen Ranges
Vent fan only works on low setting
check the bossing or the bearing of the vent put/spray oil or grease on bearing and shaft.....
Dec 09, 2013 | KitchenAid KXU2836YSS 36" slide-out vent...
Hood lights not working
Faulty switch for the lights? Measure the voltage in the lamp sockets - if you don;t know how, find someone with electrical experience to check it out.
Nov 21, 2013 | KitchenAid KHTU165RSS Stainless Steel...
Will not turn on
Hi
Your kitchen aid hood is not turning on due to a blown fuse or a faulty slide switch. Please check part#21 (Thermal fuse)---
Part#5 is the Sliding switch, if fuse is fine then replace this switch. Hope this helps... Please post back if you need more information. Daniel
Feb 27, 2011 | KitchenAid Architect II KHTU705S Stainless...
The unit says it is ventless yet it talks about venting into the soffitt. We have no soffitt. Do we close off both opening and thenit will recirculate?
In order for a ventless exhaust fan to function it needs to have the exterior vent opening closed off and it should then recirculate the filtered air.
Dec 15, 2010 | KitchenAid KHTU100KSS Kitchen Hood
Which is the best pop up down draft vent system? Do you have any reviews?
I wish I could offer some help but I am trying to solve the same question. There are almost NO reviews out there on the internet for any downdraft vents. There are also NO noise ratings on the fans (though ceiling fans all have ratings). It would seem that the taller the vent, the better positioned it is to draw off cooking fumes but other than that and the power of the motor (and perhaps ease of cleaning), I've no idea how to select a unit. HELP!
Aug 28, 2010 | KitchenAid KHTU165RSS Stainless Steel...
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Removing the fan
most fans dont come out. but it is not hard to take the hood down. there are most likly four screws in the top going down into the hood. undo them, making sure the hood is proped up. them is should just lift out of the backing plate and there is your bird. to put it back up just put it back on the backing plate then put the bults back in and make sure the vent is on properly.
Jun 18, 2008 | KitchenAid Pro Line KWCU360JSS Kitchen...
Open Questions:
KitchenAid 30 in. Slide-Out Ventilation Hood Logo
64 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
