Question about LG LD301EL Dehumidifier
HC ? what does HC mean
My DEHUMIDIFIER shows check-red light
well you didnt mention model but most times this occurs on dehumidifyers it means the bucket full sensor has tripped , this does not mean that bucket is full, it just means that bucket is either not seated all the way in or maybe the sensor has moved in the bucket and no longer hits the sensor as it should , try reposisioning the bucket and full sensor , ck for looseness
Nov 15, 2014 | Dehumidifiers
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
What do the control knob numbers mean. Does the lower the number mean less humidity?
If you have an analog unit the humidity extraction knob should be turned to Maximum.
If you have an LED screen, the arrow down button is what determines the amount of humidity to be removed and maintained. In this case, the lower the number does mean less humidity.
On an analog unit, it's the higher numbers that determine the lower humidity levels.
I hope this helps you and thanks for choosing FixYa.
Aug 16, 2011 | Comfort-Aire BHD-301 Dehumidifier
Unit will not run and the code 'LO' show up. What does the 'LO' code mean?
Hi, it simply means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
It will not run when showing that...
Jun 09, 2011 | Haier 45-Pint Dehumidifier
The humidity reading on the setting screen reads "Lo". What does that mean?
That just means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
heatman101
May 17, 2011 | Haier HDN655E Dehumidifier
Control panel explanation
80% means the humidity will be at 80%
You probably want a setting of 50 or 60% if you are trying to keep a damp area dry.
When it is 20 degrees outside, it will probably by below 50% humidity inside so you need more humidity, not running a DEhumidifier.
CONT is for continous running - you probably don't need that setting
Jan 03, 2010 | Dehumidifiers
Haier dehumidifer HD656E
What you think it means is exactly what it does mean. When a running unit is shut off it should not be restarted until the system pressures have had time to balance out so the compressor can restart without difficulty.
Jun 18, 2008 | Haier 65-Pint Dehumidifier
LG LD301EL Dehumidifier Logo
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
