A bad bearing or bad cap on an RV heatpump Coleman #6537
I have a bad bearing (most probably) or bad cap on the outdoor evap fan motor on a coleman 6537 heat pump installed in a Itasca 40KD. I need a repair manual that shows where the access to this motor is! (not accessible from in front, doesn't look good from the rear or sides and I see no way of getting at this motor from the bottom). Before I pull the bed, cabinets carpet and flooring to get at the top I would like to know if that is in fact where the access is.
    Sergeant:
  • 340 Answers
Go up top and start taking apart after ya replace the motor clean the condenser and evaporator best performance .Tom
Posted on Jun 18, 2009
Coleman ac roof rv model #6702a808 wiring to fan motor#1468a3069 diagram.
Request the fan motor wiring diagram directly from Coleman.
Jul 31, 2017 | Coleman Heating & Cooling
Remove rv fan motor
Probably not. You need to get a puller on the fan blades though
Jun 03, 2013 | Coleman Heating & Cooling
My coleman furnace in my rv just quit blowing it stays lit but the blower doesnt work it is a coleman presidential
It could be a bad temp sensor that tells the fan to come on when the heater reaches a certain temperature or it could be a bad fan motor. Take a 12 volt jump start box and hook it directly to the fan motor to see if it will spin. If it does not the motor is bad and if it does you have to replace the temperature sensor in the heater.
Mar 18, 2011 | Coleman Heating & Cooling
Mach III Air Conditioner: i have a coleman mach I rv air conditioner. Last ...
Hi, its very possible the capacitor is open or shorted. Look it over to see if it is leaking oil or swollen or even deformed. When installing a new condenser fan motor, they should sell you a new run cap with it. Its probably a 5 uf 370 volt cap and you can have it checked to see if its putting out the right amount of micro farads. If it shows any of the signs I have said, the cap is bad and you will need a new one. Does the motor spin free? If you have a meter, a digital is best, you can check to see if the motor is open or shorted to ground. Set the meter on continuity, and check each lead to ground. If it is open, your meter will show no reading. If shorted to grd, you will have a reading or a beep if your meter has that option on it. This is how you will know. If it would be best for you to take off the run cap and take it in, they can check it for you where you bought the motor. Its not unusual to loose a motor in a year as they work hard in the heat. I have seen them last for years and for just a couple of months. Keep me posted.
Best of luck to you,
Shastalaker7
May 18, 2010 | Coleman Mach III Air Conditioner
1 yr old 15,000 btu Coleman fan blows compressor not working
The power supply or compressor coil may be faulty. There could be shorted wire, open circuit, bad relay.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 14, 2009 | Coleman Mach III Air Conditioner
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
