Question about Vivitar Cameras
How do i remove the waterproof case on my vivitar 787 hd
How do I remove the waterproof casing on my vivitar 787hd? There is an arrow at the top where it looks like you stick a screwdriver and pry but I don't want to break it
  • 65 Answers
SOURCE: how to open casing
Dont do it...Whats the problem...if your under warranty or a service plan let them take care of it...
Posted on Jun 12, 2008
  • 6 Answers
SOURCE: waterproof case
no they wont it will not be the right fit try to find the right one for your camera i had the same promblem as u did and it didnt work soo try as hard as u can to find the right one for u
Posted on Jun 29, 2008
SOURCE: disassemble to repair
I just decided to try to fix mine. There are all together 5 screws. The two on the handle are covered with plastic caps which can be pulled out by sticking a duct tape and pulling it up. The other three screws are in the thumper head and are covered with the purple violet rubber piece. I removed it with my fingers. There are also two plastic bolts in the head of the thumper opposite to the handle. I removed them by using a sharp knife to loosen them and pulled with pliers.
I purchased two thumpers over time and in both the switch failed. I see that the switch in the handle is linked with the underlying mechanical switch by a very thin plastic piece. What a miserable design. That piece broke off in both thumpers rendering them unusable.
Good luck. Artur
Posted on Jan 03, 2009
slohry
  • 87 Answers
SOURCE: 066 stihl, have all screws out but can't split case.
Assuming all screws are out, intake, exhaust and cylinder, oil pump and all oil pump related items are removed Screw the clutch carrier back on to the crankshaft (this protects the crank threads) and tap the crankshaft with a brass hammer. (TAP not Whack.) The tapping should loosen the 2 halve of the crankcase. You must replace the crankcase gasket.
Posted on Apr 10, 2009
When Apple will release water-proof iPhones?
Apple has no current plans to release a waterproof IPhone. There are however several waterproof cases available that you can use in the meantime.
The following link describes 11 of the most popular waterproof cases.
http://www.digitaltrends.com/mobile/best-waterproof-iphone-6-cases/
Mar 23, 2015 | Apple iPhone Cell Phones
I have a vivitar 787hd it has a file error message on the screen. It won't turn off. It is frozen
To reset the camera remove the battery for a few seconds and replace it.
If you still get the error message try another memory card.
Dec 25, 2014 | Cameras
I have a 787HD, and am having problems deleting vidieos. The delete button does not respond most of the time, when it does it still won't delete when you hit the yes prompt,
I have encountered the same problem with mine.
This is what I do.
!. Tap rapidly on the confirm button (yes @ no) do not soft tap.
2. Use a stylus pen it's working for Me.
3. Make sure it's fully charge or plugged in.
4. With the stylus pen tap slightly left or right of the choice button you are going to use.
Hope this helps out.
Sep 19, 2014 | Vivitar ViviCam Cameras
Audiosonic action cam ASOVS002 WATERPROOF CASING.
Look for screws around the seams on the casing. Remove them.
If you cannot open it in the normal way, use an angle grinder to cut off the casing, be careful not to damage the camrera.
Dec 21, 2013 | Computers & Internet
How to pop the battery of a vivitar 882 hd camcorder
It's not sealed just, fortunately. It's just difficult to open.
The door should be on the same side of the camera as the lens.
Turn the camera upside down, and using both thumbs, push against the flat area, about 2 cm (or, about an inch) below the lens. Push from the lens toward the Vivitar name. It may not move the first time, but it should come loose after a few attempts.
This is for the Vivitar DVR 882HD. If you have a Vivitar 882 (without the DVR), it should be the same instructions, but the door to the battery case might be on the other side...I don't know if it is or not, because I don't have that version. In either case, though, just keep trying, and it should open for you.
Nov 29, 2013 | Vivitar Video Cameras
Pls any help, I connect the wingman HD to pc with the usb cable but no response that pc read it as connected device or memory disk? even i tried different pc? is that mean every time i need to download the...
Yes thats it for importing video.
i dont understand the question about underwater shooting
do you hawe a waterprof housing ? https://www.google.hr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&cad=rja&uact=8&ved=0ahUKEwjB1_PcrMzWAhUEXBoKHVlYCjcQFghLMAg&url=http%3A%2F%2Fwww.wexphotographic.com%2Fdelkin-wingmanhd-waterproof-case-1535521%2F&usg=AOvVaw0lpDYh6VUUQcaP-rAb3z2D
Sep 29, 2017 | Delkin Wingman HD Waterproof Action Camera
My sdhc card shows a 'locked' icon when i put it into my gopro 2 recorder
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 01, 2012 | GoPro Go Pro GoPro HD Helmet Hero...
Support for rsq HD-787-5 karaoke player
Hi all.
Can anyone tell me . Where I can buy a remote controller for my RSQ-HD-787.
Nov 05, 2010 | Televison & Video
IPhone case
An OEM in China called CNN.cn has made anodized iPhone’s OEM back case available as replacement parts. For $46.99 you will be able to replace the back case of your iPhone. It comes in black color and does not include the chrome Apple logo.
The back case replacement is not for the faint of heart, as it requires you to remove your current back case. It is not a simple clip and drop in cover case.
Thanks,
PREM
Mar 24, 2009 | Apple iPhone Smartphone
Waterproof case
Jun 29, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
80 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
