Question about Maytag Dryers
Pyg2000aww making loud screeching noise while running
Pyg2000aww
aborcass
  • 2651 Answers
SOURCE: amana dryer loud noise
remove the lowe acesss panel( 2 5/16 screws) wiht the panel removed and a flashlight in hand, turn on the dryer and watch it tumble. you should be able to pinpoint where its coming from. its either the rear roller supports, the front drum glide assy's, or the tension pulley in ehich the belt its wrapped arund(develops a rut in which the belt has cut into it causing horrible screeeching noise, heck to replace all three of the components is problavle ony 50 bucks or so
Posted on Apr 24, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
SOURCE: Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Posted on May 16, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Neptune electric dryer makes very loud screeching
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Sep 14, 2010
heatman101
  • 43501 Answers
SOURCE: Dryer making loud screeching noise LG Trom
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
Making loud screeching noise
I would have the disc brake pads checked as there is a spring tab that runs on the disc rotor when the pads as too far worn.
Oct 08, 2013 | Volkswagen Cars & Trucks
My ps3 makes a loud screeching noise when i turn it on
Its just dirty, clean it the best you can and make sure it has space to breathe
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Makes loud noise when running
bad berring that the drum rides in
Sep 30, 2009 | GE Dryers
I have a 1990 jeep YJ replaced the alternator and now there is a loud screeching noise replaced the belt,replaced new bearing in idler pulley still makes a loud screeching noise?
If the belt is not tense enough it will squeal, so make sure it's tight enough. Otherwise you can use a stethoscope or long screwdriver up to your ear to isolate the source of the noise.
Sep 16, 2009 | 1990 Jeep Wrangler
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Dryers Logo
16 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
