Question about Garden
Toro z5035 Motor on ,turn swich off whi problem turn swich righ .my mower no inigtion please hell my
3 Suggested Answers
bbreton
  • 437 Answers
SOURCE: Toro deck mower problem. Why my mower is using excess fuel?
Carburetor may need adjusting. The fuel you use may have an ethyl alcohol content low enough that the gas stations may not be required to post on the pumps. I know most of our fuel in this area has at least 10 percent ethyl alcohol in it. This makes fuel burn cleaner but you also use alot more fuel.
Posted on Sep 26, 2009
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Posted on Nov 11, 2012
I have a toro zeroturn mower motor starts up fine I can drive it around fine, but as soon as I engage the mower deck the motor will start running rough then stall out. why?
Could be there is an obstruction in the deck that is not allowing the blades to turn freely and stalling out the motor.
Sep 13, 2017 | Toro Garden
My mower starts cutting out after running for a hour what could be the problem ?
Ussually the cutting out is a result of a fuel problem or an inigtion component which is over heating. If you pull the spark plug out and there is still a spark then the fuel is getting blocked.
Apr 14, 2015 | Garden
Why won't my Toro aero turn
First, make sure the steer stick in moving the lever into reverse. Please check this with the engine off
Second, Check the belt tensioner. Sometimes they end up stuck which has been known to cause the belt to slip on the left transaxle only.
Third, buy a new transaxle...
Next time, include model number for a more precise answer
Apr 01, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I jave a toro timecutter z5035 and it starting making a popping noise when running. When blades are engaged the blades turn slow and the engine idles down and then will pick up running for for 30 sec
clean the spark plug or even change it , when you store it you must run it out of gas which means shut the gas off so the gas does not turn into polish that clogs you carb , needle and seat etc ,
Jan 17, 2015 | Toro Garden
WHY DOESN'T JOHN DEERE 2320 MOWER DECK WILL NOT ENGAGE?
seev if you have no voltage at pto clucth replace bad pto if you dont check fuse and pto swich and safty switch
Aug 24, 2014 | Garden
I have Toro Wheel Horse model # 71225 and does not turn over. Charger indicates full charge
pull the plug out and see if it will turn over it could have overheated causing it to lock up if it is look at buying short block are new motor but befor doing this how old is it is it worth buying a new motor
Aug 12, 2014 | Toro Garden
Why does mower die when brake released or mower engaged?
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawnmower dead
Is the gas tank is empty. Old gas can also lead to problems starting, There is a product you can add for old gas issues see your DIY or hardware store this happens often if you have last season's gas in your mower, drain your fuel tank and fill with fresh gas. some other thoughts might be Loose, Dirty or Disconnected Spark Plug Check it out, clean off debris, re-connect and tighten. Dirty Air Filter Clean or replace. Fuel Not Reaching the Engine Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Apr 12, 2014 | Black & Decker Black and Decker Mm575 18"...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
