Question about Cell Phones
Lg g2 screen jumping around - Cell Phones
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
How can I get my Verizon lg to turn on
Verizon Wireless Phone Guides - LG
www.verizonwireless.com/.../HowToControllerServlet?...
Verizon WirelessVerizon Wireless Phones. ... Note: Your model name appears on the screen immediately after turning on your device. *To view the PDF file, you may need to
LG G2 Support ' Verizon Wireless
www.verizonwireless.com/support/g2/
Verizon WirelessManage your device in My Verizon ...... Enable/Disable Voice & Video - Advanced Calling 1.0 - LG G2 ... LG G2 Simulator: Turning Airplane Mode On and Off.
Enable/Disable Data - LG G2 ' Verizon Wireless
Dec 10, 2015 | LG Cell Phones
How to unlock
i will not post the answer,i will post a site to go to,i dont believe in giving codes to someone i dont know that couldve stolen a phone,or i can flag your question, http://www.bing.com/videos/search?q=how+to+unlock+black+lg+g2+32gb&qpvt=How+to+unlock+Black+LG+G2+32GB&FORM=VDRE
Apr 21, 2015 | LG Cell Phones
Find a used phone that my lgg2 sims card will fit
The LG G2 uses a micro SIM. Any phone that takes a micro SIM and works on your carrier will work with your SIM.
Dec 13, 2014 | LG Cell Phones
Lg g2 screen froze it will not shut down it does not respond to anything i was told the battery is not removable
A soft reset is a method of rebooting your smartphone in this circumstance. On the LG G2, you can do this by pressing and holding the power button down for approximately 5 seconds. After the 5 seconds, the phone should reboot and start back up.
This method is in lieu of not having a removable battery, and it will not erase any information you have saved.
Here is a link explaining more in-depth. Hope it helps!
Soft Reset LG G2
Dec 11, 2014 | Cell Phones
How to reset lg g2 phone
It will erase everything Hardware factory reset Take your phone and turn it off just press power button and select power off.Wait while your device is shutting down.Then, press volume down button and power button together until the LG logo appears on the screen.When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.Once you do that, on your LG G2 the factory reset menu will be displayed.Press power button in order to agree and wait while the hard reset is being completed.
Aug 15, 2014 | LG Cell Phones
Lg g2 will not turn on
  1. Take your phone and turn it off - just press power button and select "power off".
  2. Wait while your device is shutting down.
  3. Then, press volume down button and power button together until the LG logo appears on the screen.
  4. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
  5. Once you do that, on your LG G2 the factory reset menu will be displayed.
  6. Press power button in order to agree and wait while the hard reset is being completed.
Jun 09, 2014 | LG G2 White for Verizon Wireless CePhone
Where to get shattered screen on LG G2 replaced?
If you do a quick google search there are lots of experts that can replace it under $75. However as android phones are diverse most malls only offer screen replacements for apple products
Apr 30, 2014 | Cell Phones
Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Oct 26, 2008 | LG Studioworks 700S 17" CRT Monitor
Brighten my computer
1.Check G2 Screen Cathode Voltage.
2.check from G2 cathode to LOT G2 supply pin It's related Low value &High value resisters.
3. replace G2 PF
Sep 22, 2008 | LG Flatron F900P 19" CRT Monitor
Cell Phones Logo
121 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
