Question about Maytag MSD2732GR Side by Side Refrigerator
Fridge less and less cold. both sides. now totally not cold. defrost timer?new fridge
  • Maytag Master
  • 4,655 Answers
The parts manual on that refrigerator show a defrost timer inside the fresh food compartment behind the control panel. Need you to turn the timer clockwise with a flathead screwdriver slowly until the compressor stops. Leave it alone for 30 minutes and if it does not turn itself back on then we need to replace the timer. If not we need to unplug the refrigerator and remove the back panel inside the freezer. We will need to test the defrost heater and inspect the defrost thermostat. Let me know when you are ready. The part number for the timer is 68233-3
Item number 13 top right hand side of photo.
1acbff1.gif Let me know if I can help, Thanks Sea Breeze
SITE-> http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
  • John Tripp
    John Tripp Jun 18, 2009
    Did not mention there should be a small opening through the control panel cover with a hole or a plastic plug that you can remove to turn the timer....Sea Breeze
Maytag refrig. not cooling enough
Posted on Jun 26, 2009
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My LG side by side frig. is not cold enough
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Good luck
Aug 01, 2010 | LG Refrigerators
No power & not running
Hi, you have to check few things, first of all check power at the outlet for 120 volts. If the light in the fridge works, the defrost timer, cold control and possibly the wiring are the most common things that can make a fridge sit there and be dead, not working.
The defrost timer might be stuck in defrost, turn the timer screw to advance the timer and if the fridge comes back on, replace the defrost timer. You can join the wires together to by-pass the cold control for a test, if the fridge comes on, replace the cold control...
Take care
May 02, 2010 | LG LSC26905TT Side by Side Refrigerator
Freezer on bottom, cold, fridge not cold,ice on
Probably the difusser door that allows cold air from the freezer into the fridge portion, either stuck or control dial faulty
Aug 22, 2009 | Refrigerators
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not getting cold enough. the temp in the fridge is 66.6! help please! less then a yr. ago i replaced the gasket, so i know it's not that. i also have it on the coldest setting. i wasn't having...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
GE side by side. Freezer cold, fridge kinda cool
your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
May 29, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Maytag MSD2732GR Side by Side Refrigerator Logo
403 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
