My washing machine av61 ariston front loader washing machine it's does not spin while washing and what was the problem of washing machine
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Mar 31, 2015 | Ariston Technologies Washing Machines
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
Do you have a manual foe AV61 ariston washing machine please
Manual for this machine can be found at:
http://www.instructionsmanuals.com/u2/pdf/lavadora/Ariston-AV61-en.pdf
Jan 30, 2010 | Ariston Technologies Washing Machines
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
I GOT MACHINE FROM eBAY,I DONT HAVE MANUAL
usa www.the-manuals.com
uk www.instruction-manuals.co.uk
Nov 09, 2009 | Blenders
Instructions are not in english
http://www.instructionsmanuals.com/modelo-2149-en-Washers.htm
If you click on the above and look down the page click on english and then download.
Oct 30, 2009 | Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
