Question about HP Photosmart 735 Digital Camera
HP Photosmart 735 Camera lasts 2 minutes with fresh batteries
After installing a fresh set of batteries, within 2 minutes the "low-battery" error message flashes on the display and shuts the camera down.
    Sergeant:
  • 321 Answers
Use NiMH batt.
Posted on Jun 18, 2009
Camera won't stay on with new batteries
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) should not be used. hey have limited power and can leak in a short time, destroying a camera.
Feb 05, 2014 | HP Photosmart 735 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
<div class="solution-text"> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.<br><a href="http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html" target="_blank" rel="nofollow"><br>http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html</a><br><br><b>Fix #1:</b> Remove the batteries fromthe camera, wait a few minutes. Put a fresh set of batteries back in(preferably rechargeable NiMH 2500mah or better) and turn the cameraon. If that didn't work, try pressing and holding the Function or OKbutton while turning the camera on. <br><b>Fix #2:</b>If the camera's batteries ran down completely while the its lens wasstill open, the camera may show a lens error or not start properly whennew batteries are installed. Remove the memory card and keep itremoved, then install the new batteries. When you turn the camera onwith the card removed it may come back to life, as this triggers areset in some cameras. Error E30 (for older Canon's) means that youdon't have a memory card installed, so turn it off, slip in the <a href="/support/t5307069-lens_error_lens_not_open#" target="_blank" rel="nofollow">SD card</a>and turn it on one last time </span> </div> <!-- /solution text --> <!-- helpful bar --> <span class="br"></span> <!-- /helpful bar --> <p class="add-comment"> <a id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1_lnkHeader" onclick="javascript:ShowHideForms('ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1');" lang="6652"><br></a> </p>
Aug 24, 2010 | HP PhotoSmart M627 Digital Camera
Will not power on. ive put in new aa batteries
Try this:
- remove the batteries
- wait more than 60 seconds
- reinstall (fresh/charged) batteries
Mine was exhibiting the same problem ... it would start to power on, but died as soon as the lens began any motion at all. It would power up fine on AC power, or on the dock. I was going to install new firmware on the camera to try to fix the problem. Reading the firmware installation instructions indicated that, to complete the firmware upgrade, the batteries would need to be removed for at least 60 seconds, which I'm guessing forces the camera into some sort of deeper reboot/restart.
Apr 12, 2010 | HP Photosmart 735 Digital Camera
Even with fully charged batteries, the camera won't turn on. what can i do?
Try this:
Mar 14, 2010 | HP Photosmart 735 Digital Camera
I have an hp 735 photosmart camera which I am very pleased with but my husband has broken the lid which covers the batteries so the camera will not work. where can I get one of these covers from?
You can get the cover from the same retailer where you purchased the camera from, or you can order it from HP. Alternatively, a good camera shop can repair it for you if you have no experience in working with tiny screws that hold the lid in place.
Oct 06, 2009 | HP Photosmart 735 Digital Camera
E106 problem
hi my name is steve i am somewhat familiar with the 735 photosmart,2 things to fix this yourself is go to hp.com,look up your camera model and download your firmware your problem is error 106 your zoom lense is stuck plug your camera up to the usb and go on to hp.com youll find the firmware there follow the instructions after you download it the comp. will send the firmware right to your camera and presto your fixed your camera will opperate properly and your camera will have this up to date firmware its like a flaw with these and the firmware will fix it free of charge let me know if everthing is sucessful after and take care.
Oct 01, 2008 | HP Photosmart 735 Digital Camera
HP photosmart M417
My M417 that I just got at a garage sale works fine but when I put a set of freshly charged NiMH batteries in it will only work for a couple of minutes before the camera will say they are dead and shuts down. When I test the "dead" batteries they each have over 1.25 volts and flow over 8 amps through a dead short (the meter). I have upgraded the firmware. Any ideas?
Rob
Jan 04, 2008 | HP Photosmart M417 Digital Camera
Battery level low
welll the problem is is that you have to buy special batteries like alkaline normal bateries will not last and will always come up with that error message
Aug 31, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart 735 Digital Camera Logo
237 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
