Question about Dell Dimension 4600 PC Desktop
I have replaced (6) or more dell 4600 motherboards on my computer.I am trying to find a place to refurbish the ones that I have.All were hit by lighting and I'm sure all have same problem.any help.
    Sergeant:
  • 268 Answers
I would be willing to test them out for ya but if they got hit by lighting there scrap at this point.
Company site http://www.attechcomputers.co.cc
Posted on Jun 18, 2009
I recently replaced the motherboard, video card and hard drive in my dell d800. The hard drive is new, but when I try to boot-up the computer gives an error message that there is no hard drive detected....
If it says there is no hard drive detected, then the BIOS is looking for one.
When you place your system disk in the drive to load on a fresh system, if you are using Windows, it will automatically detect the pressence of a hard drive, initialize it and format it. If it doesn't, put the hard drive in a USB caddy and initialize it from another pc, then place it back in the notebook.
Hope that helps.
Nov 24, 2010 | Dell Latitude D800 Notebook
I had new harddrive put in my dell 4600. now it freezes up sometimes it wont boot up. now technician says my motherboard is bad .it sometimes takes up too three tries too boot the computer up.. and now it...
I agree with the technician. Contact Dell, and order a replacement motherboard, and get the technician to remove the old motherboard, and install the new one -- it should *NOT* be necessary to reinstall Windows, if the replacement motherboard is identical to the original motherboard.
Nov 06, 2009 | Dell Computers & Internet
Dell 4600 no monitor signal
Hey Tony,
If you haven't already: pull all pci cards:
If you pull the ram, and you get no beeps at post, it's likely the main board. Does the pc beep at all? with or without ram? If not, likely the main board. Sorry. Hope this helps...
Aug 17, 2009 | Dell Dimension 4600 PC Desktop
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
PC Battery voor een Dell 4600
When I boot I get an error message - and I think the battery is to be replaced, what and how should I do?
Thanks in advance for the answer! 1. Turn the computer off. 2. Disconnect the power-cable. 3. Remove the side-panel. 4. Look on the motherboard for a silver-coloured circular piece, about 2 cm. in diameter. 5. Read the lettering on the top of the piece. 6. VERY CAREFULLY remove the piece, by lifting from one edge. 7. Take it to a computer-store, and buy a replacement. 8. Check the lettering on the top of the new piece. 9. Insert the new piece, with the lettering on the new piece matching the lettering in #5, above. 10. Replace the side-panel. 11. Reconnect the power-cable. 12. Start your computer. 13. Immediately, press DEL to enter BIOS-setup. Set the date & time. 14. Save/Exit from BIOS-setup. 15. Reboot.
Apr 05, 2009 | Dell Dimension 4600 PC Desktop
Internal battery needs to be replaced on my Dell Dimension 4600.
Unplug the computer. Remove the side cover. This is probably held on by two or three philips head screws on the back left edge of the unit. On the motherboard, look for a flat, round, shiny piece that resembles a nickel. This is the battery. There should be a small metal tab that holds it in place. Push on the tab and the battery should pop out. Note the orientation of the battery and replace with a new one in the same position.
Jan 18, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600 desktop PC
turn on your computer and when you see the dell splash screen hit the ctrl key and f11 key and see if you get to see the symantec restore message. if you do see it you can restore your pc to its factory default. if after doing that nothing happens try to restart your computer and when you get to see the dell splash screen pressd f8 5 to 6 times until you get to see the advance boot menu and see whether repair my computer is one of the selection if it is select it and choose restore you pc to factory default. if nothing appears on the advance boot menu of repair my computer. the only option is to do a clean reinstall of your operating system
Jul 08, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
56 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
