Question about Samsung DMT400RHS Builtin Dishwasher
Samsung dishwasher heavy smart error code - Samsung DMT400RHS Builtin Dishwasher
Samsung dishwasher not finishing was cycle flashing smart auto and normal lights at same time and not draining out water please help
http://www.appliancepartspros.com/diy-story-error-code-over-fill-flashing-smart-auto-diy916377.html
Apr 22, 2017 | Samsung Dishwashers
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Why on the Samsung DTM400 series dishwasher are normal heavy and smart/auto lights all flashing?
That's a High-temp Heating Error. It's usually caused by a bad ECS sensor. You will need to call a professional repairman to replace it. (I recommend Sears).
Aug 17, 2014 | Samsung Dishwashers
Why are the heavy and smart auto blinking?
That's an over-level water error. The case-break assembly is bad and needs to be replaced.
Jun 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Why does the Heavy and smart auto lights flash simultaneously after cycle starts?
It means "over-level water error". Usually caused by a bad case-brake assembly.
Jun 05, 2014 | Samsung Dishwashers
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
Samsung DMT400RHS Builtin Dishwasher Logo
52 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
