Question about Panasonic VIERA Televison & Video
Usb port not working on vierra tv - VIERA Panasonic Televison & Video
USB Port not working, any solutions?
In looking up this TV, it doesn't show a USB port anywhere.
The manual doesn't mention it. NewEgg doesn't mention it. C/net doesn't mention it.
There's a pc audio port, VGA, 75ohm antenna, 3 HDMI and a Coaxial.
Did you mean any of these?
If there is a USB, it's probably only used for software updates.
Jul 31, 2016 | Coby Televison & Video
I can not find an HDM1 port on my Sharp TV. Can I use the USB Port?
No, the HDMI plug will not fit into a USB port. (It's the wrong shape and the pins are different.) The micro-USB port can be connected to some USB ports for power, not data, with the appropriate cable (micro USB to type A). (Without the model of your Sharp TV, I do not know if the USB port has the right specifications. Some older TVs only have a "service port" which doesn't always provide enough power.)
There are HDMI to component video/audio converters that may work. They do not always work with copy protected (HDCP) content. See http://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html for one example. (Composite video is not recommended since that will downgrade the signal to 480i. Component video supports 1080p signals.)
If you have 1 HDMI port, then a multi-port HDMI switch may work. Note: automatic switches often do not switch on their own with some sources. If the source never actually turns off, like some set-top boxes, you'll need to switch the unit manually.
I hope this helps.
Mar 05, 2016 | Amazon Fire TV Stick
Plugged in USB device on Panasonic vierra gave me overload warning screen went haywire. Now it won't turn on . no blinking light though
usb overcurrent error message on plasma tv - PC World Forums
pressf1.pcworld.co.nz > Forum > PressF1
Jul 4, 2012 - 10 posts - ‎5 authors
we have a panasonic viera tv ( plasma) when i plug in my 1st portable ... Since thedevices are not powered the overcurrent warn isn't from external sources which leadsme to think there is a physical problem with the 2nd drive. ... for the TV doesn't work, try getting firmware for the drive from WD's site, that ...
How To Use DLNA And External HDD On Your Viera TV ...
? 4:08
https://www.youtube.com/watch?v=JqeLDaB5nvQ
Feb 9, 2011 - Uploaded by PanasonicUK
http://www.panasonic.co.uk/ How to setup and use the DLNA andUSB HDD functions on Panasonic Viera TV's. ... Is there not any way to access an external hard drive without recording ... I can record using the HDD but it doesnt let me record SCART or HDMI, why is this? ... Anyone have the same issue?.
Dec 25, 2015 | Panasonic Televison & Video
How do i connect compaq 6710 b laptop to my tv
by using HDMI cable ......there is an HDMI slot available in laptop as well as tv . purchase HDMI cabe and u will b able to connect ur laptop with ur tv.
Nov 24, 2012 | HP Compaq 6710b Notebook
Connect laptop to tv
Use VGA, HDMI, or DVI cable. You must have same conection on laptop and on TV. Install latest video drivers !
We have a 50"panasonic vierra
Tv have problems with it 2 backlight buffer boards,like to help the tv Plasma screen panel to stay consistantly lite with same brightness.Take ur tv back where u bough it.Trade it in for another tv this tv have deffective and dying backlight buffer boards.
Sep 04, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have an LG42LH40 and ive had 2 situations when i turn on a tv in another room one of the hdmi ports go out. ive had to use the other hdmi port and the cable or ps3 works fine but not in the 2 other...
Are you aware that all the new HDMI devices have interactive technologies . For eg: if you are watching cable TV and switch on your Blue ray player connected via HDMI, you will notice the TV will automatically switch to that HDMI input with you having to pick up the Tv remote and switch manually. Some find it irritating, but you can disable that function in your system Menu. Panasonic calls it Vierra link / Sony calls it Bravia sync etc.....
Mar 08, 2011 | LG 42LH4000 42" HDTV-Ready LCD TV
The set top box is flashing red and no picture panasonic vierra
Try a UHF antenna input to the Panasonic vierra? If the TV is good replace the set-top box?
Sep 19, 2010 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
