Question about Kodak EasyShare LS743 Digital Camera
Kodak easyshare LS 743 won't format SD memory card
Once I insert an SD card into my camera it says "memory card needs formatting". I click continue. It then says "formatting will delete everything on memory card". clink continue again and it repeats that same process. Ive also tried formatting the SD card on my computer first, and that isn't fixing the problem. I've already tried about 4 SD cards and none are working. What do I need to do to fix this?
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Posted on Mar 28, 2009
  • 942 Answers
SOURCE: Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Posted on Jul 06, 2009
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Posted on Oct 25, 2009
shockwave727
  • 262 Answers
SOURCE: Kodak EasyShare DX4530 Digital Camera Digital
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
Posted on Nov 08, 2009
  • 11967 Answers
SOURCE: kodak easyshare c613: memory card says its full
If you connected the camera to the computer with a USB cord to download your pics and then just yanked out the cord without using the "safely remove hardware" icon at the bottom right corner of your screen, the card may have been corrupted. Replace it.
Posted on Nov 10, 2009
How do I format a SD card in aKodak V570 digital camera
Make sure you have an SD card. If your card is 4GB or larger then it's actually an SDHC card and won't work in your camera.
Aug 18, 2012 | Kodak EasyShare V570 Digital Camera
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
Memory card will not format in Kodak Z760
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    C190-caot be read with 2 differnd SD 4GB cards. Is
    Hi sir
    #1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    # 2 Open up 'My Computer'. You should see it under the list of available drives.
    # 3 Check its contents first to make sure that you have the right drive.
    # 4 In 'My Computer', right-click on the drive and choose 'Format'.
    # 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    # 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Mar 15, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
    Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
    Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
    Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
    Formatting memory card
    it's just gonna loop if you're using a card more than 1GB. This particular model will only work for 1GB or lower SD/MMC card.
    Aug 05, 2009 | Kodak EasyShare C330 Digital Camera
    Memory card needs formatting.
    take a look at your memory card to make sure it is not locked, then try formatting you memory card
    Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Kodak EasyShare LS743 Digital Camera Logo
    19 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
