Question about Maytag PTB1954GR Top Freezer Refrigerator
Ice cube maker
The back half of the tray is not cold enough. The ice cubes form one huge ice chunk. The freezer temp is set to 7.
  • Maytag Master
  • 4,655 Answers
We need to check the defrost timer first. It's located inside the fresh food compartment and inside the control panel. There should be a small opening through the panel that you can place a flathead screwdriver. Turn slowly clockwise until the refrigerator compressor stops. Leave it alone for about 30 minutes. If it does not restart then the timer is bad and will need replaced. If not then we need to unplug the refrigerator and remove the rear panel inside the freezer and inspect the defrost heater and defrost thermostat. Let me know when you need more assistance, Thanks Sea Breeze
Timer part number may depend on if the model is correct listed above your post. Part # 68233-3
SITE-> http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
  • John Tripp
    John Tripp Jun 18, 2009
    I am curious, did you choose to set the freezer to 7? Has this always been your choice for the freezer area? Most refrigerators set both settings to 5. I just want to see if I understand your question correctly. Sea Breeze
  • John Tripp
    John Tripp Aug 09, 2009
    The back half of the tray is not cold enough. The ice cubes form one huge ice chunk. The freezer temp is set to 7. I tried to anwer your question and you said nothing but click not helpful? For one thing your question relates to your ice maker and there are 1000 answer I coul bring to you on that topic. I tried to help you and you choose the wrong person as not helpful!
    You are welcome to contact me at appliancepartsoutheast@live.com Let me know if you really need help. Sea Breeze
Ice made but will not dump.
Hello, There is a heater in the bottom of the tray where the ice cubes are formed. The heater melts the bottom of the ice cubes just enough to release the ice cubes from the mold. I suspect your mold heater is not working.
Oct 13, 2015 | Refrigerators
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
RS267 Ice is not dispensing
The freezer temp is not cold enough, the ice cubes melted and giot welded together and now the motor will not turn, you have to unplug it, wait until it melt a little take the drawer out and get rid of the old ice, clean the tray, and make sure it is completely dried before putting it back in, use paper towel to dry it.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jan 14, 2018 | Samsung RS265LABP Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice machine wont dump ice on sears kenmore side by
Ice forms are 32 degrees but ice maker don't dump till 25 degrees. Get that guy back out there. Obviously you have a bad defrost heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | Refrigerators
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106 52542101,WILL NOT EJECT ICE (SIDE BY SIDE)
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Sep 17, 2008 | Refrigerators
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Samsung, american style fridge
hi lemmy, i will find out from samsung tech and get back to you, this is an unusual prob,,
Jun 04, 2007 | Samsung RS2630SH Side by Side Refrigerator
Maytag PTB1954GR Top Freezer Refrigerator Logo
89 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
