Question about Vizio GV42L 42 in. LCD Television
Vizio 47" remote
Brand new,,(4 days) Remote lights up but only volume adjusts. Can't get menue or anything else to work.. Vizio 47"
    President:
  • Vizio Master
  • 1,779 Answers
If your manual buttons on the set do not work, then I would return the set. If they do work then contact the store on where to get a warranty replacement remote, or just go back to the store with the remote and see if it works on another Vizio.
Posted on Jun 18, 2009
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
We replaced the IR sensor on our Vizio but still cannot control the volume via the remote (which has tested good). Any further suggestions?
Since sensor is receiving the signal of other inputs, there is nothing wrong with it. This looks like an incompatibility issue. You may have to retry using the original remote control.
Jul 30, 2012 | Vizio SV470XVT 47 in. LCD TV
My tv will freeze on menu
Looks like there is/are jammed button/s in the remote. Try removing the batteries from the remote and using control panel of the TV.
Jul 28, 2012 | Vizio M470NV 47 in. LCD HDTV
47 in vizio tv keeps freezing when i go to menu
Look for jammed buttons on the remote or on TV.
New 47" Vizio tv.
Look at your remote and there should be a menu button. Once in the menu you will see a screen section that will let you select between 4:3, 16:9..... Toggle through those until you find the one that works with your tv.
Also there may be a button on your remote that looks like a box with an arrow pointing left and right. Click on that and it will toggle through the same thing mentioned above
Jul 25, 2011 | Vizio 42 in. LCD TV
The remote on my Vizio 47" LCD TV sort of stopped working. It still does volume and basic things, but power doesn't work and neither does changing the input...it's incredibly frustrating. I swapped in...
Try website 1-800-remotes Factory original.Buy an exact remote.Ur old remote is dead,main CPU chip is sorted.Can't repair this olny replaced with a new remote.
Mar 18, 2010 | Vizio SV470XVT 47 in. LCD TV
Vur9 remote only controls the volume and nothing else, cant change channels or anything any suggestions?
Press the TV button on the lower right (not the upper right) to tell the remote to control the TV.
The upper buttons are the Input Selector buttons. The lower buttons are the Device Control Selector buttons.
I had this same problem until this dawned on me.
Apr 20, 2009 | Vizio VO47L 47 in. LCD TV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
242 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
