Question about GE Profile PCF23NGW Side by Side Refrigerator
GE Prifile model pcf23ng, the refrigerator side was 87 degrees. The dome light was out and very hot. I reset the controls to 37 degrees and it turned on and stabilized to temperature overnight. What caused this problem?
    Problem Solver:
  • 23 Answers
Did you have an electrical storm? If so, may have surged the circuit causing unit to shut down or perform erratically. Also could your refrigerator door have been partly open just a small crack causing the light to stay on and warm air to enter raising the temperature and braking the circuit breaker making the entire unit to shut down and you happened to notice this right after the unit shut down... I say right after because it is difficult to imagine a light bulb that is "out" being "very hot".
Posted on Jul 11, 2014
  • 213 Answers
SOURCE: GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Posted on Nov 30, 2007
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
Posted on Apr 28, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
GE bottom freezer PF22missaww i came home from vacation and it was at 60 degrees , unplugged it for 10 minutes and plugged it back in , ran fine for a month , came home from work and the unit is warm again...
GE Profile bottom freezer erratic.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which may have reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 13, 2017 | Refrigerators
Hi need a manual for GE Profile side x side PCF23NG/TSC#NS
Go to GEAppliances.com and use your model number to search for free downloadable manual.
Mar 25, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature reverts back to old number which is 33 and is too cold for vegetables. How can I set it to 37 degrees
set the controls to off. then , unplug the unit from the wall for 15 minutes. this will allow the control processor to completely reset itself . after fifteen minutes, plug it in and reset your desired temperatures on your controller. if this does not work, I would suggest you consult the manufacturer or your owner's manual for more information on programming the temperature controller.
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
2002 GE sidebyside is freezing the lettuce/water froze in filter
Model # would be helpful, but most likely something going in with damper that controls airflow between freezer and fridge side. Also could be thermostat
Nov 07, 2017 | GE Profile PSW26P Stainless Steel Side by...
The refrigerator part of the side by side is 25 degrees when I have it set for 37 degrees
Check the thermostat Knob. Turn it to off then back to c or 3 let it run for 12 hours and recheck.
Nov 04, 2009 | GE Profile PSI23NCR Side by Side...
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PCF23NGW Side by Side Refrigerator Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
