Question about Epson Expression Premium XP-800 Small-in-One Printer
Epson copy size too small
Copy is half size
2 Suggested Answers
SOURCE: Epson CX 4200 won't copy originals when placed on the glass.
printer won't print, red light flashing
Posted on Jan 24, 2010
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
I can't make a copy using the operator's mode. the copy that does print is so light and such small print thatit can hnardlyh be read. Also, the copy that comes oujt is only half of a page. Most of the
It sounds like the settings on your printer in the menu area have been set to reduce the image you want to print? Click on menu and then scroll the features with the up and down arrows and check on the size of the image to print and change it if necessary.
Please clairfy what you mean by "using the operators mode".
Oct 21, 2011 | Dell V305 All-In-One InkJet Printer
Epson Stylus SX100/TX200 Cannot get carriage to stop in position to change a cartridge - red light is flashing
Are you using the "ink cartridge replacement" utility? To access this utility click "print" as though you were going to print a document. This should open a small window that will have check boxes that allows you to enter how many copies and what size of paper you wish to use. Also on this small window is a button that says "Properties". Click that button and another small window will open with 3 tabs across the top that say "main" "page layout" and "maintenance". Click the maintenance tab. On the maintenance tab there should be about half a dozen utilities that you can start by pressing buttons in the window and one of those utilities is called "ink cartridge replacement". Once started, this utility will give you several instructions and advise you to click "next" after completing each step. One of the steps will cause the carriage to move into a position from which you can change the cartridge. Good luck!
Dec 06, 2010 | Epson Stylus Photo R320 InkJet Printer
Font too small in printing aol emails
try copying all text from the email and pasting it in a text program if this problem still incurs sorry i couldnt be of help
Jan 15, 2010 | 3Com Computers & Internet
Copy split in half; half blank/half print
It is a scanner problem. You need to take in in for a service tech to repair. It could be the scanner bulb, or laser.
Jan 08, 2010 | Sharp Office Equipment & Supplies
How can i copy a legal size document on the Epson Stylus CX9400?
Take a photo with digital camera. I am doing this on newspaper articles from books at local Historical Society then cropping and other editing in my Serif Photo Plus 11 program.
good luck,
LindaC in OK
Jan 28, 2009 | Epson Stylus CX9400 Photo Printer
Epson V200 scanner
Epson V200 Copy Utility Problem with Incorrect Margin Output
I had the same problem forever and i just sat down today to fix it.
I have a Konica Minolta PagePro 1350w for my printer. The resolution
is set default at 600x1200 when in the Output Paper - Paper setting.
Change the resolution for your printer if you can to 1200x 1200 in the output paper - paper setting in the copy utility software, and
that should solve your problem with this half page copies. It might
still cut off some margins at the very edge, but most of the time they're just
plain paper margin. Hope this helps you out.
Jul 04, 2008 | Epson Perfection V200 Flatbed Scanner
Paper size..
In WIN98 with WordPerfect9 we had set up dot matrix printer Epson LQ1050 on which to print 8.5" wide by 5.5" long (half page) multipart invoices. In XP apparently MSFT changed this and there is no custom paper size in windows printers. Instead one must use the program's (Word Perfect) page setup where the page size can be entered. Problem is the Epson drivers have not been rewritten to incorporate this change. The optional paper sizes are builtin to the printer drivers. Some folks with the same situation as you have had success using the Forms menu in MS Fax to set different paper sizes. Third party programs such as FinePrint (www.fineprint.com) can also help with this. I hope you work it out ;]
Apr 23, 2006 | Epson TM U210A Matrix Label Printer
Epson Expression Premium XP-800 Small-in-One Printer Logo
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
