Question about Refrigerators
Ge model gss201epc frost in freezer - Refrigerators
eagle338
  • 4889 Answers
SOURCE: freezer no frost
This is probably due to the failure of defrost timer or the heating coil..Try this
1)The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
2)If this doesnt work then Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
Posted on Oct 15, 2007
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: GE Model TFX25KRCGWW there is frost in the freezer
Just went throught he same thing. The evaporator coils ( the ones in the freezer section) have defrost heaters that cycle occasionally to keep them frost free and they are not working. It could be the defrost thermostat, defrost timer, or the heater elements. The timer is the first thing to check followed by the thermostat and then the heater elements. Advice, help, and parts are available along with detailed diagrams of the refrigerators at several web sites:
http://www.appliancepartspros.com/partsearch/
http://www.repairclinic.com/Home.aspx
http://www.pcappliancerepair.com/
http://www.partselect.com/default.aspx
Posted on Apr 18, 2009
Maytag317
  • 1136 Answers
SOURCE: frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: I have a GE side
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Posted on Dec 20, 2010
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Ge model gsl25jfpb bs not getting cold
Is it plugged in Is the compressor running ? Is it cool at all? Is there frost on the back side of the freezer wall? If there is frost on the back wall of the freezer the defrost circuit is usually the culprit there is a heater or heaters under the back panel of the freezer compartment.they might need to be replaced
Aug 01, 2014 | GE Refrigerators
GE MODEL # GSH22JSDSS IS NOT COOLING
I had a different problem recently on a different model GE refrigerator. My Fridge was up to about 45-50F. Check in the freezer. Is there frost on the back panel inside the freezer? Mine had about a half inch of frost on it. It\'s an indication that the defrost cycle is not working which was due to a temperature sensor on the evaporator that had gone bad. It\'s an inexpensive part that is easy to replace. Most GE\'s use part #AP3185407 (WR55X10025). It was around $9 plus shipping from appliancepartspros.com. First, unload the fridge and freezer and defrost it. Remove the back inside panel of the freezer and the evaporator will probably be caked with frost. Use a hair dryer to remove the rest of the frost. You\'ll see a small white bulb with a double white wire coming off it clipped to the top of the evaporator. Cut the wires and remove the old sensor. Attach the wires of the new sensor to the wires you cut from the old sensor (either solder or use a crimp but connector or similar). Put it all back together and you are in business. I hope this helps.
Jul 03, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
HIGH LOW
HIGH LOW
Normal
Coldest
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
GE refrigerator model PSS27MGMBB Freezer is not working
Open the freezer door and look at the back wall. If there is frost on the back wall, you have a defrost problem, which means air cannot circulate over the cooling coils located behind the freezers back wall. You will have to remove the back wall and melt all the frost with a hair blower, then replace the defrost heater. (part number WR51X10055) . This is assuming that the fan by the compressor and the one inside the freezer are working.
Jul 01, 2009 | GE PSS27MGM Side by Side Refrigerator
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
