Question about Audiovox Vehicle Parts & Accessories
How to program audiovox prooe3saw using toggle switch
Where is the programming/valet button on the antenna located
Every installer puts the valet button in there desired location under the dash, most older audiovox units had a small chrome toggle switch, some had a red push button, a lot of units had extra programming switches with cables that the installer never put in, they just threw it away after progamming, those plugged into a socket on the side of the unit, a green connector possible on older units, you need to get the model number to be specific
Feb 09, 2014 | Prestige Remote Start
Prestige a1btx
Try changing the batteries in the remote first before you start pushing buttons and flipping switches.
Feb 06, 2014 | Audiovox Vehicle Parts & Accessories
Where is the red switch that is turned off when servicing Audiovox pretige remote car starters?
there is usually a red toggle switch down in the kick panel or on the knee bolster. It is silver and has a red rubber boot on the toggle switch. This may not be there if the tech did not install it.
Dec 06, 2010 | Car APS921 Remote Starter - Keyless Entry
Cant buy pass brake on my vm9311ts
use toggle switch on inout bypass code with remote
May 10, 2010 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
I need a manual for APS686T for the wiring diagram. the remote start is not working.just power locks and alarm.
sounds like the unit is in valet mode or the hood switch is broken. check for the hood switch or look for a toggle switch that might be under your dash. if switch is located turn switch on and try remote start.
Sep 12, 2009 | Prestige APS686T Remote Start and Keyless...
I DO NOT HAVE INSTRUCTIONS FOR THE AUDIOVOX MVDVD4 DVD PLAYER IN MY VEHICLE AND I AM NOT GETTING THE SOUND. DO I NEED TO TURN MY RADIO TO A CERTAIN FREQUENCY? THANKS
Most FM modulators most commonly run on FM frequency 88.1 or 88.3 but usually have several options, so play arround with the stations in that range, and see if you get sound, also look under the dash for a toggle switch of sorts, sometimes the modulators have to be turned on..
Aug 14, 2009 | Audiovox MVDVD4 Car Video Player
Bypassing the emergency brake on the xdvd9101 with a toggle switc
ground wire to a normal 2 position toggle switch. put dvd in. turn switch on then off then on. there ya go.
May 03, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
SOund with a dvd player
There may be a toggle switch on the dash. siwtch it to on and tune into FM (88.7 or 89.1). Ours was 89.1. Hope this helps
Mar 15, 2008 | Audiovox MMDV2
Vehicle Parts & Accessories Logo
112 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
