Liebert nx Bypass STS Fail
Liebert gxt2-10000rt208 fault indicator and A + E LEDs on. Did anyone know this alarm?
I'm going to go on a limb and say the unit also has the bypass indicator on as well, is that correct? A=On bypass due to overtemperature condition & E=On bypass due to inverter failure.
I can't see in the picture or hear it but is it beeping also? 1 second beep every 2 seconds? Thats on internal bypass. If none of this is true then you have a tricky problem.
Dec 09, 2014 | Liebert Computers & Internet
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
Liebert gxt3 1500
staticbypass is actvated by the main control card via the press button swith,to transfter back to online mode its still the control card that do the timing for the transition to take place so i would suggest you test with another control card or try and be patient and see if it takes longer time to transfer back to online mode.
May 13, 2014 | Liebert Computers & Internet
Why software for clear fault on liebert ups nx 40 kva
The software allows you access the battery life monitor and reset it. It is the only way to clear the fault
Apr 29, 2014 | Liebert Computers & Internet
WHY IS LEIBERT GXT2U BEEPING
What is the beep cycle? You can determine why it is beeping by reading the user manual. For example a beep for 1 second at 2 second intervals means the UPS is in bypass
Apr 24, 2014 | Liebert UPStation GXT 2U GXT2-1500RT120...
Emerson UPStation, Liebert GXT21000RT120. 2 tower battery is continuing to alarm. Bypass light is on and AC input light is on. This happened after dropping a plastic water bottle on top of the main...
Hi Tammy, this can only be done if the load is not critical....
If load is critical then shut it down first.
On bypass you will be getting one beep every min or so
Try pressing the inverter on button, there should be a single beep, and then if all is well the inverter will come back on line. All leds will then be green.
Suggest once working that it be checked to see if it will still support load during outage.
If this does not work then please post again.
In the manual there is pages of fault diagnostics which may assist, if you don't have the manual it can be downloaded from the Emerson website.
Hope this helps,thanks for using FixYa
Vote for this if you like it.
Sep 13, 2011 | Liebert Computers & Internet
Hallo, we are installing 2 NXE 120kva 3 phase 480V UPS and been getting conflicting advice on bypass MODULE That we need.. could someone help us in resolving this scenario
Yes, I need to know what scenario you speak of though. You are setting these units up in tandem, or how are you configuring them? It should be pretty straightforward, what are you trying to bypass?
Tim
Sep 27, 2010 | Liebert PowerSure PSI UPS System
Need to monitor status of Liebert 150 KVA UPS
Try to find your manual here in this site. Choose your Product Category, Product Application, Application Type and Specific Product. After that you can download the manual. Hope this helps. "http://www.liebert.com/servicesupport_pages/ProductDocumentSelector.asp"
Jun 03, 2009 | Liebert Computers & Internet
Need repair manual for Liebert UPStation GXT1500RT
Hello gypsy6767, I spent 10 years as a Liebert Rep here in the Phoenix, Az. market! Here is a link to the Liebert GXT User's Manual - http://www.liebert.com/common/ViewDocument.aspx?id=1199
I hope this helps,
map6260
Mar 12, 2009 | Liebert UPStation GXT1500RT...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
