Question about HEWLETT-PACKARD HP ProBook 6455b(WZ237UT) NoteBook AMD Phenom II Dual-Core N620(2.8GHz) 14' 4GB Memory DDR3 1333 320...
Hp probook 6455b won't boot up
Drive light is amber
3 Suggested Answers
  • 6771 Answers
SOURCE: blinking white amber light above power cord
The power supply is the issue, or the DC jack in the laptop has developed bad connections, or ram issue. Remove 1 stick of ram and power on, if no! remove second one, and replace the first, power up, if no! test the power supply for proper voltage, if okay! it is a DC jack or motherboard problem.
Posted on Mar 10, 2012
bronk50
  • 27725 Answers
SOURCE: how to unlock hp probook 6455b
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Posted on Aug 27, 2012
Hp probook 6455b will not turn on why?
Take everything out of it that you can. That would mean the ram and drives, see if it boots. IF it does, then put the ram back and check it again. If it does put the hard drive back etc. If you get to the point that it wont boot with nothing installed then it could be a dead cmos battery or a loose CPU or something like that or a bad mother board.
Apr 04, 2016 | HP Computers & Internet
No power on HP ProBook 6455B
Try removing the charger and the battery, then replacing the changer while the battery is out. This does a hardware reset that can sometimes solve issues like yours. If that doesn't work, you could be correct in assuming it's the button. If you're brave you can check the connection of the button to the mainboard. In this video: http://www.youtube.com/watch?v=Am6na_9HDww at 5:24, you can see the ribbon cable just above the keyboard connection, re-seating this may also solve your issue.
Thanks,
Liam
Sep 16, 2013 | HEWLETT-PACKARD HP ProBook 6455b Notebook
Bios
Which software are you trying to reinstall? Are there any error messages?
Jun 06, 2013 | HEWLETT-PACKARD HP ProBook 6455b Notebook
How to use 2 external monitors with hp probook 6455b
You can plug the first monitor to the VGA port and the second to the DisplayPort to the left side of the laptop
Notice: you will need a separate cable to be able to use DisplayPort
You can buy it directly from HP HERE:
http://h10010.www1.hp.com/wwpc/ca/en/sm/WF06c/A1-329290-64268-1844682-1844682-3769762-3769765.html
Dec 20, 2012 | HP ProBook Computers & Internet
I'm trying to find the motherboard model number for the ProBook 6455b, any help would be greatly appreciated...
if you need motherboard then I can sale you working and tested motherboard for your ProBook 6455b
Nov 14, 2012 | HP Computers & Internet
Webcams
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 11, 2012 | HEWLETT-PACKARD HP ProBook 6455b(WZ237UT)...
Blinking white amber light above power cord
Mar 09, 2012 | HEWLETT-PACKARD Probook 4530S
HEWLETT-PACKARD HP ProBook 6455b(WZ237UT) NoteBook AMD Phenom II Dual-Core N620(2.8GHz) 14' 4GB Memory DDR3 1333 320... Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
