Question about Motorola Mobility H350 Wireless Headset
How can i get pairing of the device? - Motorola Mobility H350 Wireless Headset
  • abojanah_e12 Jun 18, 2009
    how can i get pairing of the device?
What type of phone do you have
Posted on Jun 18, 2009
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
I dont have the code to my bh-602
According to the manual it is 0000
I added an excerpt of the manual here :
Pair the headset
1. Ensure that your mobile device is switched on.
2. To pair the headset if it has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light flashes blue quickly.
To pair the headset if it has been previously paired with another device, ensure that the headset is switched off, and press and hold the power key until the indicator light starts to flash blue quickly.
3. Activate the Bluetooth feature on the mobile device, and set it to search for Bluetooth devices. See the user guide of your device for instructions.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your device. In some mobile devices, you may need to make the connection separately after pairing. See the user guide of your device for details. You only need to pair the headset with your device once. If pairing is successful, the headset appears in the menu of the mobile device where you can view the currently paired Bluetooth devices.
Mar 21, 2011 | Nokia bluetooth headset bh-602
Blueant wont accept pairing with my phone, it was working OK and the blue light is flashing
if you can pair 2 phones on this blueant you might try to pair the second phone to the device lay them on a table
when pairing any device you must set the bluetooth activate on active devices and then in the settings select search for active devices or pair a new device
(this may vary depending on the device you are pairing)
hope this helps
Jan 18, 2011 | Computers & Internet
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Pairing bluetooth to my phone
  • general instructions for no specific phone and device to pair
    • turn on both devices (phone and other device)
    • on the phone search for a bluetooth devices(that is on)
    • if the other device is asking for a password, enter a known password to success the pairing
    • or else it will pair automatically for a non password pairing
May 03, 2009 | Lands Phones
Motorola Mobility H350 Wireless Headset Logo
401 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
