When unit is turned on, display appears to start but within a second or two it switches itself to standby mode and does not work.
Solutions?
Comments:
Nov 03, 2007
- This seems to be the consensus from searching the web... trouble is I am not sure how to identify and test the resistors to determine which one may be faulty. Of course if you take it to a shop it is not worth the price of fixing it so it is something you really have to do yourself to make if cost effective.
Thanks so much, Brent.
Nov 04, 2007
- Thanks Les,
My location is near Guelph Ontario in Canada should anyone want to volunteer assistance with this problem.
Les I wondered if there are some generic instructions somewhere on the web that you know of that may get me started?
Cheers, Brent
PS Actually at the moment I am in Jordan in the Middle East on an working assignment... the world is getting smaller!
This fault may be similar to a Harmon Kardon AVR1550 fault I recently encountered. I did all the usual checks e.g. testing for presence of DC on speaker outputs etc. but all seemed fine, then the fault cleared! Next day it re-appeared and attention was (falsely) given to the protection circuits as the amplifier circuits themselves were considered to be in order. The HK uses both voltage and current protection circuits and it was discovered that the current protection circuit was operating. Eventually the fault was found to be one of the 0.39 Ohm 3W metal oxide resistors that had gone high in value on the left hand channel. Of course your amplifiers fault may not be due to this but the reason for going into standby would probably be the same i.e. due to amplifier protection circuits operating. You need to check out all the output devices and those resistors on every channel, even surround ones you may not be using. Hope this helps.
Comments:
Nov 03, 2007
- Emitter resistors
Nov 03, 2007
- Hi Brent, perhaps you could highlight geographical area where you live with a request for help, you may get someone who lives near you to offer you help. I would always be happy to do so but I doubt if by some chance you live near Watford - England, you could even be residing in the States or anywhere else in the World! Just a thought, there are knowledgeable people out there willing to assist. Les
The source selector just starts changing input sources all by itself. Then once started it might...
(More)
The source selector just starts changing input sources all by itself. Then once started it might just keeping going for minutes. Is there a way to prevent this from happening?
Currently have a Denon avr 3805 with no HDMI output. Trying to hook up Sony BDP 360 Blue Ray using...
(More)
Currently have a Denon avr 3805 with no HDMI output. Trying to hook up Sony BDP 360 Blue Ray using optical adio through the receiver and direct HDMI from blue ray to TV. The audio works but getting no picture.
I have a UPA-100 amp as part of a 4 piece 100 set, which refuses to power up. The system switches on...
(More)
I have a UPA-100 amp as part of a 4 piece 100 set, which refuses to power up. The system switches on via the UTU-100 Tuner unit and the amp used to make a discernable internal 'click' before powering up the. Sadly no more. I vaguely remember the system having some kind of delay after switching on whilst it checked that the volume was not set too high before power was passed on to the remainded of the system. Maybe it is this switch that has now failed.
