Question about Samsung Televison & Video
How to remove the casing for the SR3000 portable TV
Clean ID Sensors
Are you looking for how to clean the TD sensor???? I'm not sure what a ID sensor is??? The TD sensor is above the transfer belt unit. You will have to remove the 4 drums & transfer unit and clean the inside area of the copier. Good Luck
May 21, 2012 | Lanier Ld 425c With Df/print/scan/fax/4...
I am haveing trouble getting the remote to program my tv. I do not have the or the instructions for either the remote or my tv. The tv that i am useing is a SR3000. Could you please instruct me on how i...
Hello brandiek1:
Try this site for your manual, just Click "HERE"
Hopefully it will work for you.
If it does just click the thumbs up button.
Sincerely, Peter N.
Mar 22, 2011 | Televison & Video
How shrink picture size in AKAI 14" portable TV
Less power output from the internal SMPS; usually 110v, may less. Horizontal output capacitor may leaky. Horizontal output transistor fault may occur. In rare cases deflection yoke assembley fault.
If the picture is stamped size; suspect the power supply. If the picture is less in width, suspect the above said capacitor, and the lenearity coil fitted on the main board.
Oct 13, 2010 | Akai LCT0510 5 in. Portable TV
How do i remove the plastic mounting bracket from the tv?
Look for any screws that may be connected with the mounting bracket, keeping it attached to the tv. If you cannot find any screws visible then they may be hidden.
In this case, try to gently pry away any part of the mounting bracket that looks like it comes away from the tv. This may reveal screws or the mounting bracket may have simply been clipped in.
Oct 24, 2009 | GE 09GP110 Television
How do i hook up my 16-454 to my verizon fios cable?
I am not sure what a FIOS use, but I was able to split my cable connection and was connect my regular TV AND portable tv with the cable.
IN YOUR CASE:
Look at your fios set up box, behind the box, there should be something that would say "TO TV" or "VIDEO OUT" or "TO TV/VCR"
Usually, the cable coming out from there goes to your regular TV. So instead of your regular TV, you can connect that with your portable TV.
AS FOR MY CASE (Having 2 tv's),
1. I removed the cable that is connected to the wall (RF IN or From WALL or CABLE IN).
2. I hooked that end to the "IN" part of a 3 way splitter
3. I bought a short cable and connected one end to the Cable Box and the other end to the OUT of the splitter
4. I bought a longer cable and connected one end to the portable TV and the other end to the OUT of the splitter.
5. Then I turned on the TV and pressed MENU
6. I clicked the right arrow until I see ANTENNA. I pressed the down button to choose CATV instead of AIR.
7, I did auto scanning.
My portable TV now has the basic channel while the big TV (since it is connected to the cable box) has the added digital channels. Nevertheless, it is great to have both so when I want to sleep, my hubby can just use the small tv
Jul 02, 2009 | Accurian 16-454 Television
Disassembly of JVC KT-SR3000
Did you get it open? remove the two screws. Those are all the screws on the outside. Gently pry the halves apart at the bottom of the unit. Gently try a flat screwdriver. GENTLY! Theres some tabs that hold the rest together. You may break one or two but will be ok in the end. Do the prying at the bottom so you dont break the tabs at the top.
Apr 09, 2009 | JVC KT-SR2000 SIRIUS Radio Receiver
Dog ate my sr3000 remote
get a logitech harmony, very easy to setup using computer.
Feb 28, 2009 | Marantz SR-3000
KT-SR3000
Had this problem with mine. turned out to be bad solder joints. Take the unit apart and solder these joints and it should fix the display problem.e0ae4d7.jpg
Jul 31, 2008 | JVC KT-SR2000 SIRIUS Radio Receiver
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
