Question about Toys
Tap handle removal faucet style - Toys
  • 148 Answers
SOURCE: Handle Removal on Chateau Style Bathroom Taps
the handle removal is a metric allen wrench some of the cartridge replacements come with an allen head wrench
I always plug the drains and completely remove the allen head screw then the handle comes off
Sometimes you have to pry it gently or take a hammer wrap a towel around the handle where it meets tthe cartridge base and tap up under the handle lightly and it comes out
God Luck
Posted on Dec 31, 2008
  • 14 Answers
SOURCE: water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Posted on Jan 03, 2009
  • 7 Answers
SOURCE: leaking hotwater from the tap
You have two options. You can either replace the faucets- which is much easier for a novice, or you can rebuild them. As far as removing the handles, double check and make sure there is no set screw. If there is not, then the handles should come off. You may have to gently rock each one from side to side. Once you get the handles off, you should see where the valve unscrews. Now would be a good time to turn off the main water going to the tub. Once that is done carefully unscrew the valves and remove them. Take this to Lowes or Home Depot and you should be able to find repacking kits. They usually have full installation instructions included.
Posted on Sep 27, 2009
Testimonial: "GreaT"
  • 760 Answers
SOURCE: Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Posted on Jul 12, 2010
Dplumber
  • 119 Answers
SOURCE: How do you remove the handle son a Grohe two-handl...
Pull the handles straight out of the faucet. use both hands to pull back on the hand while wiggling it left and right just a little at a time. Eventually it will pull off.
Posted on Dec 12, 2010
Have crane tap set , two taps and a spout with an in and out lever to shower or fill tub.I have no cold water when tap set is in place, when i remove the tap set from the fixture i have water flow.
Look inside the faucet handle for damage. A cracked handle would need replacing, as it cannot grip the faucet stem. If the ridges inside the handle are worn, the handle cannot connect with the stem and control the faucet.
Inspect the end of the faucet stem for damage. The tip of the stem should have ridges that connect with the ridges inside the faucet handle
Nov 08, 2016 | Home
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How do I fix a leaky, old style, screwless faucet?
there is a screw under the center c or h label,or there is a nut that needs to be turned to take the cartridge out
Jun 08, 2015 | Plumbing
Remove the handle from graff kitchen prescot faucet- stuck
you may have to use a little force gently pry under the handle be extremely careful not to break handle i usually take a piece of wood to put up against faucet or whatever and then tap faucet with hammer then start prying back side with a screwdriver or small breaker bar use your hand to try to wiggle the handle
Aug 30, 2014 | Graff Plumbing
How do I remove the cartridge?
most single handle styles have a crown nut or collor ..allen screw under handle 1st 1/8 allen , then wiggle cartridge . upward ..shut off watter 1st good luck';';'
Mar 24, 2011 | Kindred Brush Nickel Single Handle Kitchen...
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
How do you remove the handle son a Grohe two-handle classic style faucet
May 20, 2010 | Grohe Classic Kitchen/Bar Faucet ...
How to remove a pegasus faucet handle, brushed nickel, dual handles
with most fausets there will be a cover hiding the setscrew holding it in place. it'll be right on top and need to be pry'd up. or the piece you'd use to turn the handle with, will unscrew.
Sep 15, 2009 | Pegasus Technologies Widespread Lavatory...
God Luck
Nov 28, 2008 | Moen Chateau, Two-Handle Garden Tub Faucet...
Toys Logo
166 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
