Question about Citizen Televison & Video
Dvd stuck in dvd player will not eject - Citizen Televison & Video
SOURCE: DVD got stuck
I've seen complaints that there is no manual eject. There is. Unplug. Facing the front of the player, and lifting it up above your head, look under where the disc sits. You will see a number of slits that look like ventilation slits. There is one asymmetrical slit on its own, somewhat towards the front, and somewhat towards the right (if memory serves). The slit is about 3/4 of an inch long. Insert a slotted screwdriver on the extreme right end of the slit (still we're facing the front) side of that slot (a narrow shaft might help, but it doesn't have to go very far in). It should sound like it hits plastic. If not, you may have the wrong slot and you may have shorted things out (I suppose an electrician's plastic screwdriver, or a chopstick shaved into screwdriver shape, would work better). Then slide the screwdriver to the left. You should hear/feel unlatching noises, and the front of the loader should wiggle, and you should then be able to pry it forward (maybe using a screwdriver for leverage) and pull out the disc. When the player dies, it would be nice if it didn't take your--or worse not your--DVD with it.
Posted on Dec 28, 2006
SOURCE: dvd stuck in dvd
There is a elease button on one side of the tray you can get to with a paperclip
Posted on Aug 27, 2007
  • 3 Answers
SOURCE: Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Posted on Aug 11, 2008
  • 59 Answers
SOURCE: DVD stuck in DVD player will not eject
I just fixed one of this exact model SD-V392SU with same problem. This takes a bit of manual dexterity, but it can be done with some care and patience.
THE PROBLEM:
There is a small plastic nylon gear on the shaft of a miniature motor in the DVD mechanism. This gear is likely floating loose in the machine. It is what connects the motor's shaft to the rest of the mechanism to operate all it's functions which include opening and closing the tray and raising and lowering the laser and spindle motor that spins the disks. Be careful not to lose it once the lid is removed from the unit. It is quite small.
Unplug the unit and use a well lit area to work in such as the kitchen table covered with a large towel to protect the unit and the table.
There are 5 Philips head screws holding the lid on. One each side and 3 in the back. Remove those paying attention to where they come from. There is a subtle difference in the lengths of the screws. I use empty prescription bottles to keep things sorted when I work.
The lid can be removed by sliding it slightly backwards and tilting the rear of the cover upwards and back. Once the lid is off the unit, you must locate the small white nylon gear that has come off the shaft of the miniature motor that drives the mechanism. A good tip is to lay out a dark colored large towel to shake and dump the loose gear out and onto so you can more easily see it's white color.
REMOVING THE DVD MECHANISM:
There are 2 flat ribbon connectors and one 3pin mini molex connector connecting the DVD mechanism to the main board of the unit. Grasp the cables as close to the connector as you can get.and gently disconnect these by carefully pulling them out. All three are different, so you can't mix them up to put them back.
There are four screws holding the black plastic mechanism in the unit. One long shoulder style screw at the rear center of the mechanism, and three short screws with captive washers. Two of the three short ones are located one on each side of the mechanism towards the front face of the unit and one near the right hand side about three quarters of the way to the rear of the mechanism. A magnetized Number 2 Philips is the best tool for removing and replacing these screws as the two short front screws must be removed from rather tight quarters in the recesses of the unit. The magnet holds the screws on the tip so you can raise and lower them into position while removing and replacing them.
Once the three connectors and four screws are removed, you can lift the rear of the mechanism slightly and tilt the mechanism out of the unit. Once again, keep a sharp eye out for the loose little white gear.
Now that you have the mechanism out of the unit, you can manually eject the captive DVD.
First a little about how this mechanism works.
Look at the front face of the mechanism. You will see a white actuator bar that slides left and right. This is what raises and lowers the laser/spindle assembly. When the mechanism motor spins, connecting gears move this bar raising the laser/spindle motor assembly up. This causes the disk to be clamped against the top of the drive in play mode so the spindle motor can rotate the disk for the laser to read, The disk tray is basically locked when in this position and it can not slide out to give you the disk.
With the gear missing from the mechanism's motor, it will be possible to move that white actuator bar that raises and lowers the laser/spindle motor assembly. Note that there is a switch with three wires on it located on about front face center that is operated by that white bar. This switch tells the mechanism motor when it is loaded and unloaded so the motor knows when to stop spinning as it loads and unloads. Once the bar lowers the laser/spindle, the tray should be able to be coaxed out. Looking at the bottom of the mechanism, you may be able to spot the gear so you can assist the mechanism's white actuator bar, but with the motor's gear missing, the other gears can spin freely.
Once you have your disk out and you have found that little white gear, you can begin the actual repair of the mechanism.
Looking at the bottom of the mechanism, you can see the bottom of the motor the little white gear came off of. This is NOT the spindle motor that spins your DVD's Once you know where that motor is, you can imagine where the shaft of it will appear on the top. Viewing the top of the mechanism, there is a combination of gears that that little gear drives and you should be able to find the motors bare shaft pointing up. This, of course, is where that little white gear belongs.
Now there is two ways to put the gear back on the shaft. I removed the two other gears this one meshes with so I had a little more wiggle room. The other way, of course is to leave the other gears in the way. This makes replacing the small gear more difficult as there is less room for error in placing the gear.
The gear closest to the front of the mechanism has a plastic hook that can be very slightly moved aside to allow that gear to come off it's shaft. Note the difference between the top and bottom of these gears so you know which way they go back on. Once the one with the hook holding it on is off, the other one can just slide off it's axle as it is held in place by the first gear you took off.
I used some Q-tips and alcohol to clean the shaft of the motor and the inside center of the little gear. Then I used a poor man's bearing mount (clear nail polish) and a plastic tooth flossing tool to apply a very thin coating to the inside of the gear and a Q-tip for coating the outside of the shaft to help keep the gear from coming off again. This must be very carefully applied as you don't want any excess nail polish running down the shaft of the motor and getting in the bearings of the motor. There is a special fluid called bearing mount for fixing pulleys and gears on shafts, but I didn't have any of it or the commercially available thread lock. Bearing mount is basically just very thin, watery thread lock like fluid.
I used the small pick end of the tooth flossing tool to position the gear over the motor's shaft and then pressed it back on using a small screwdriver. The gear is very light, so the tackiness of the nail polish was enough to hold it to the tooth pick's curved pick end. Give the nail polish at least an hour to dry before attempting to move the mechanism. Now that the gear is in place, things can't free wheel any more and you don't want to stress the gear before the polish has had a chance to dry.
Once the gear is pressed back on the shaft of the motor, you put the other two gears back where they came from and it's ready to go back in the unit.
Tilt the front of the mechanism down slightly as you slip it back into position. Note that the back end of the mechanism has a small recess where the rear supporting post fits into. All the holes for the screws should be lined up before you start putting them back in. A good tip is that I always turn the screw counterclockwise or reverse after placing it in the hole and wait for it to thump or click down again before turning it clockwise in. That way I know the screw is seating properly and won't cross thread. It turns back in very easily or I reverse again.
Hold the ribbon cables as close to the end as you can as you put them back in their sockets. There is a small amount of reinforcement near the ends of the ribbons to assist in plugging them back in. Otherwise, it's like shooting pool with a rope. :o)
Replace the lid with the rear of it tilted up and slide the front under the face of the front bezel. Everything should fit nicely and the screw holes should all line up. If it doesn't, you've got it wrong, try again.
That's about it. I hope this helps.
Posted on Feb 22, 2009
  • 111 Answers
SOURCE: There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Posted on Feb 03, 2010
Testimonial: "Thanks a lot! It worked. Now I'm afraid to use the DVD player. Maybe I'll put in an old kid movie that we don't watch anymore and see if it works. "
How do I remove a stuck DVD?
It sounds like your problem isn't the dvd is stuck, since it seems to be spinning up, it sounds more like your ejection system has stopped working for some reason.
To fix either you are going to have to remove the outside case of the dvd player and expose the internal chassis. There are anywhere from 4 to 8 screws holding it on on the bottom and back of the unit, Make sure the dvd player is unplugged before you remove the cover.
Once you have the cover off, if the dvd is simply stuck, you should be able to see what the issue is; is it misaligned in the housing was it inserted incorrectly, are there in fact 2 dvds in the player, etc, etc. Gently remove the dvd and replace the case and enjoy.
If you can't see any reason for it to be stuck it may be the ejection system. The eject system will have a belt and sprocket system to move the tray or push out the dvd depending on the player. Make sure the belt is on the wheels correctly and that the sprockets mesh properly. If you can't see anything wrong try testing the ejection system with the case off.
Make sure you don't have any objects in or touching the dvd player, you don't want to short out any of the components if a screw fell into the dvd player onto the mother board, etc. Plug the dvd player back in, make sure you don't touch the inside and try to eject the dvd. Watch the ejection system and you should be able to figure out what is going wrong. Once you have figured it out unplug the unit and put the items back together. If you can see that something is broken then you will have to determine if you can have it fixed or if it wouldn't be cheaper to simply ditch that unit and purchase a new one.
Hope this helps.
Oct 12, 2015 | Televison & Video
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
There's a DVD stuck in my car DVD player and it won't eject. How do we get it out manually?
There may or may not be a small pin hole in and around the entry point similar to computers where you can push in a wire to eject.
Apr 05, 2013 | Car Audio & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I have 2006 honda odyssey. i cannot use dvd system, because i cannot eject dvd. how can i eject dvd?
To eject the dvd from the dvd player you have to push the eject button on the dvd player, if the dvd is stuck inside the dvd player you have to get it checked by a service technician
Feb 27, 2010 | 2006 Honda Odyssey
In the rear of the player is a small hole to eject the CD. Straighten a paer clip and push it in the hole to eject the CD.
Dec 22, 2009 | 2006 GMC Yukon Denali
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Televison & Video Logo
Top Citizen Televison & Video Experts
Electro Med Services...
Are you a Citizen Televison and Video Expert? Answer questions, earn points and help others
