Question about Craftsman Garden
Engage&disengage not working staling out engine
When you engage -engine bogs down and wants to stall ,engages deck for a second or two
    Problem Solver:
  • 11 Answers
Sounds like a siezed mandral or idler pulley,possibly the belt jumped off and is caught between a pulley and the deck or belt guide
Posted on Jun 18, 2009
Why does a craftsman tracor with a kohler 15.5 hp engine bogg down when engaging blades
It will initially bog down when engaging, but should pick back up shortly after. If it is staying bogged down, turn mower off and check inside (under) the deck to make sure its not clogged up with grass clippings or dirt. if it is, clean it with either a hose or a scraper. Also make sure the deck is raised when you engage (dont engage with deck lowered on long grass).
Jun 15, 2014 | Craftsman Garden
What is causing my enginge to stall when I try to engage my mower deck?
Check the seat switch it might be disconnected. It will cut the mower off if you leave the seat without disengaging the deck.
May 24, 2014 | John Deere L100 Series
Motion belt was recently replaced and the mower seemed to be operating as intended; mowed the lawn with no problem. The next time I tried to use it I discovered that, as soon as the mower deck is engaged,...
This could well be a miro switch issue, start with the seat switch make sure the connector is fully pushed onto the micro switch, if no better make sure you are fully sat in the seat to activate the switch, if still no better replace the switch.
Jul 31, 2013 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
JD STX38 mower stalls when deck is lowered
If the belt bounces then it has stretched or the belt tightener is not working. properly. Also check the shear pin in the drive pulley. If it has sheared the blades will try to turn but slip when any pressure is put on.
Jan 07, 2018 | Garden
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Yth1848xp bogs down at full throttle when engaging the mower
Carburetor could possibly need cleaning or rebuild, Governor linkage could be dirty and not operating freely, or it could be out of adjustment
Sep 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Scotts mower kohler command 25 motor bogs when mowing
Hi..my name is Keith..and it sounds like you have a binding somewhere on your mowing deck..i would check all the spindles .. pulleys and blades..and check the deck belt..it could have jumped a belt guard and it running on the outside of it..but just remember it has pulley brakes to slow the pulleys down when you shut it off..so..engage the deck without the engine running and check for the binding..i hope this has helped..if not..please write me back
Jul 14, 2009 | Garden
Garden Logo
121 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
